Salta al contenuto principale
Vtech InnoTab 3 Rear Panel Diassembly
Cosa ti serve
  1. Vtech InnoTab 3 Rear Panel Diassembly, Rear Panel: passo 1, immagine 1 di 3 Vtech InnoTab 3 Rear Panel Diassembly, Rear Panel: passo 1, immagine 2 di 3 Vtech InnoTab 3 Rear Panel Diassembly, Rear Panel: passo 1, immagine 3 di 3
    • Slide the battery compartment door lock down.
    • While still holding the battery compartment lock down, slide the two battery doors outwards on either side of the device.
    • Carefully remove the batteries from the battery compartment.
    • The standard option for the InnoTab 3 is four AA batteries. Vtech also offers a rechargeable battery online, but both battery options are removed from the device the same way.
  2. Vtech InnoTab 3 Rear Panel Diassembly: passo 2, immagine 1 di 1
    • Remove the six 7.6mm screws found in the battery compartment using a PH00 screwdriver.
  3. Vtech InnoTab 3 Rear Panel Diassembly: passo 3, immagine 1 di 3 Vtech InnoTab 3 Rear Panel Diassembly: passo 3, immagine 2 di 3 Vtech InnoTab 3 Rear Panel Diassembly: passo 3, immagine 3 di 3
    • There are three hidden screws on the back of the device, two at the top and one near the bottom.
    • Using a nylon or metal spudger, remove the three caps that hide the screws.
    • Remove the 5mm screw near the bottom and the two 7.6mm at the top using a PH00 screwdriver.
  4. Vtech InnoTab 3 Rear Panel Diassembly: passo 4, immagine 1 di 1
    • Carefully separate the back panel from the front panel revealing the motherboard connected to the front panel.
Conclusione
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 11
Tutti i Tempi: 1,306
