Salta al contenuto principale
Vornado 133 Compact Air Circulator Fuse Replacement
Cosa ti serve
  1. Vornado 133 Compact Air Circulator Fuse Replacement, Fuse: passo 1, immagine 1 di 1
    • Ensure the unit is powered off and remove the plug from the outlet.
  2. Vornado 133 Compact Air Circulator Fuse Replacement: passo 2, immagine 1 di 3 Vornado 133 Compact Air Circulator Fuse Replacement: passo 2, immagine 2 di 3 Vornado 133 Compact Air Circulator Fuse Replacement: passo 2, immagine 3 di 3
    • Slide open the fuse access cover on the top of the plug by moving it towards the end of the plug.
  3. Vornado 133 Compact Air Circulator Fuse Replacement: passo 3, immagine 1 di 3 Vornado 133 Compact Air Circulator Fuse Replacement: passo 3, immagine 2 di 3 Vornado 133 Compact Air Circulator Fuse Replacement: passo 3, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    • Use a pair of tweezers or a small plastic spudger to remove the fuse from the fuse casing. Remove the end nearer to the fan body first, then the end nearer to the plug end.
    • The replacement fuse must be 2.5 amp, 125 volt.
    • Do not push against the glass center of the fuse, only the metal end pieces.
Conclusione
Follow these instructions in reverse order to install the new fuse and close the access panel.
Altre 11 persone hanno completato questa guida.
Erin Klein
Membro da: 07/06/17
483 Reputazione
3 Guide realizzate
UW Tacoma, Team S1-G2, Liner Summer 2017 Membro di UW Tacoma, Team S1-G2, Liner Summer 2017
UWT-LINER-SU17S1G2
4 Membri
4 Guide realizzate
10 Commenti
Great post! This saved me $60 from buying a new fan! Thank you!
jamiekim808 - Replica
Thanks for posting. Ordered a pack of 50 fuses from amazon for $7.97
TLCIMMORTAL - Replica
Fast-acting or slow-acting?
James Olsen - Replica
Wow, I was going to throw this fan in trash and seeing your instructions I saved it
Anupam B - Replica
thanks buddy, just bought the fan ,son stuck a pencil in it , Quick fix
BOBBY C - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 29
Ultimi 30 Giorni: 97
Tutti i Tempi: 33,729
