Salta al contenuto principale
VooDooQuad 250 Propeller Replacement
Cosa ti serve
  1. VooDooQuad  250 Propeller Replacement, Propeller: passo 1, immagine 1 di 2 VooDooQuad  250 Propeller Replacement, Propeller: passo 1, immagine 2 di 2
    • Unplug the power cable of the drone to eliminate unnecessary mishaps.
  2. VooDooQuad  250 Propeller Replacement: passo 2, immagine 1 di 1
    • With your set of pliers loosen and remove the four bolts holding the propellers to the motor.
  3. VooDooQuad  250 Propeller Replacement: passo 3, immagine 1 di 2 VooDooQuad  250 Propeller Replacement: passo 3, immagine 2 di 2
    • Gently remove the propellers perpendicular to the device.
    • When placing the new set of propellers on the drone, make sure that the wings angled upward are facing towards the center, or the battery.
Conclusione
Be careful removing the bolts multiple times because it may create slippage and then this will not allow the bolt nor the propeller to stay on. To reassemble your device, follow these instructions in reverse order
Damir Pamic
Membro da: 02/15/17
141 Reputazione
1 Guida realizzata
USF Tampa, Team 10-3, Remmell Spring 2017 Membro di USF Tampa, Team 10-3, Remmell Spring 2017
USFT-REMMELL-S17S10G3
4 Membri
1 Guida realizzata
1Commento della guida
Where do I purchase new perpelers
Will Smith - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 18
Tutti i Tempi: 695
