Salta al contenuto principale
Voluas VL001 Screen/Motherboard Assembly Replacement
Cosa ti serve
  1. Voluas VL001 Screen/Motherboard Assembly Replacement, Storage Tank: passo 1, immagine 1 di 3 Voluas VL001 Screen/Motherboard Assembly Replacement, Storage Tank: passo 1, immagine 2 di 3 Voluas VL001 Screen/Motherboard Assembly Replacement, Storage Tank: passo 1, immagine 3 di 3
    • Remove the lid to the storage tank by using the latch and lifting off.
    • Grab the food storage tank on both sides. Depress the tabs that say "Push" on them and lift the tank off.
  2. Voluas VL001 Screen/Motherboard Assembly Replacement, Battery: passo 2, immagine 1 di 3 Voluas VL001 Screen/Motherboard Assembly Replacement, Battery: passo 2, immagine 2 di 3 Voluas VL001 Screen/Motherboard Assembly Replacement, Battery: passo 2, immagine 3 di 3
    • Place your pet feeder upside down.
    • Squeeze the lock and remove the battery cover.
    • Remove the three 1.5V D alkaline batteries.
  3. Voluas VL001 Screen/Motherboard Assembly Replacement, Housing: passo 3, immagine 1 di 3 Voluas VL001 Screen/Motherboard Assembly Replacement, Housing: passo 3, immagine 2 di 3 Voluas VL001 Screen/Motherboard Assembly Replacement, Housing: passo 3, immagine 3 di 3
    • Insert a metal spudger under the adhesive part of each rubber foot.
    • Pry the foot off.
  4. Voluas VL001 Screen/Motherboard Assembly Replacement: passo 4, immagine 1 di 2 Voluas VL001 Screen/Motherboard Assembly Replacement: passo 4, immagine 2 di 2
    • Remove four screws from the corners of the device using a Phillips #2 screwdriver.
    • These holes were previously covered by the rubber feet.
    • Using the magnetic tip of the screwdriver, carefully lift the screw out of the hole.
  5. Voluas VL001 Screen/Motherboard Assembly Replacement: passo 5, immagine 1 di 1
    • Turn the device over so it is oriented right-side up.
    • Lift the top part of the feeder off, exposing the mechanisms that run the feeder.
  6. Voluas VL001 Screen/Motherboard Assembly Replacement, Screen/Motherboard Assembly: passo 6, immagine 1 di 2 Voluas VL001 Screen/Motherboard Assembly Replacement, Screen/Motherboard Assembly: passo 6, immagine 2 di 2
    • With the top part of the feeder sitting upside down, you can remove the chute.
    • Using a Phillips #2 screwdriver, remove the two 11.1 mm screws on either side of the chute.
  7. Voluas VL001 Screen/Motherboard Assembly Replacement: passo 7, immagine 1 di 2 Voluas VL001 Screen/Motherboard Assembly Replacement: passo 7, immagine 2 di 2
    • Grab the feeder chute on both sides and lift it off to remove it from the feeder.
  8. Voluas VL001 Screen/Motherboard Assembly Replacement: passo 8, immagine 1 di 3 Voluas VL001 Screen/Motherboard Assembly Replacement: passo 8, immagine 2 di 3 Voluas VL001 Screen/Motherboard Assembly Replacement: passo 8, immagine 3 di 3
    • Using your finger, depress the tab that holds the assembly onto the device.
    • While pushing the tab down, push the screen out of the device.
  9. Voluas VL001 Screen/Motherboard Assembly Replacement: passo 9, immagine 1 di 3 Voluas VL001 Screen/Motherboard Assembly Replacement: passo 9, immagine 2 di 3 Voluas VL001 Screen/Motherboard Assembly Replacement: passo 9, immagine 3 di 3
    • Using an opening tool, pry the dried silicone from around the connector.
    • Because you are working around the motherboard, try to limit how much you use its surface for leverage. It is a fragile part and can damage easily.
    • If needed, peel any remaining glue off with your fingers.
  10. Voluas VL001 Screen/Motherboard Assembly Replacement: passo 10, immagine 1 di 3 Voluas VL001 Screen/Motherboard Assembly Replacement: passo 10, immagine 2 di 3 Voluas VL001 Screen/Motherboard Assembly Replacement: passo 10, immagine 3 di 3
    • Firmly grab the connector, just above the plastic end, and pull firmly to remove.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 29
