Salta al contenuto principale
Voluas VL001 Main Drive Gear Replacement
Cosa ti serve
  1. Voluas VL001 Main Drive Gear Replacement, Storage Tank: passo 1, immagine 1 di 3 Voluas VL001 Main Drive Gear Replacement, Storage Tank: passo 1, immagine 2 di 3 Voluas VL001 Main Drive Gear Replacement, Storage Tank: passo 1, immagine 3 di 3
    • Remove the lid to the storage tank by using the latch and lifting off.
    • Grab the food storage tank on both sides. Depress the tabs that say "Push" on them and lift the tank off.
  2. Voluas VL001 Main Drive Gear Replacement, Battery: passo 2, immagine 1 di 3 Voluas VL001 Main Drive Gear Replacement, Battery: passo 2, immagine 2 di 3 Voluas VL001 Main Drive Gear Replacement, Battery: passo 2, immagine 3 di 3
    • Place your pet feeder upside down.
    • Squeeze the lock and remove the battery cover.
    • Remove the three 1.5V D alkaline batteries.
  3. Voluas VL001 Main Drive Gear Replacement, Housing: passo 3, immagine 1 di 3 Voluas VL001 Main Drive Gear Replacement, Housing: passo 3, immagine 2 di 3 Voluas VL001 Main Drive Gear Replacement, Housing: passo 3, immagine 3 di 3
    • Insert a metal spudger under the adhesive part of each rubber foot.
    • Pry the foot off.
  4. Voluas VL001 Main Drive Gear Replacement: passo 4, immagine 1 di 2 Voluas VL001 Main Drive Gear Replacement: passo 4, immagine 2 di 2
    • Remove four screws from the corners of the device using a Phillips #2 screwdriver.
    • These holes were previously covered by the rubber feet.
    • Using the magnetic tip of the screwdriver, carefully lift the screw out of the hole.
  5. Voluas VL001 Main Drive Gear Replacement: passo 5, immagine 1 di 1
    • Turn the device over so it is oriented right-side up.
    • Lift the top part of the feeder off, exposing the mechanisms that run the feeder.
  6. Voluas VL001 Main Drive Gear Replacement, Main Drive Gear: passo 6, immagine 1 di 3 Voluas VL001 Main Drive Gear Replacement, Main Drive Gear: passo 6, immagine 2 di 3 Voluas VL001 Main Drive Gear Replacement, Main Drive Gear: passo 6, immagine 3 di 3
    • Remove the two 11 mm screws that attach the portion switch to the device using a #2 Phillips screwdriver.
  7. Voluas VL001 Main Drive Gear Replacement: passo 7, immagine 1 di 2 Voluas VL001 Main Drive Gear Replacement: passo 7, immagine 2 di 2
    • Using a Phillips #2 screwdriver, remove the single 13 mm screw that is found in the center of the main drive gear shaft.
  8. Voluas VL001 Main Drive Gear Replacement: passo 8, immagine 1 di 3 Voluas VL001 Main Drive Gear Replacement: passo 8, immagine 2 di 3 Voluas VL001 Main Drive Gear Replacement: passo 8, immagine 3 di 3
    • Firmly grab the gear and remove it from the device.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 3
Tutti i Tempi: 65
