Salta al contenuto principale
Vizio VTAB1008 Wi-Fi Antenna Replacement
Cosa ti serve
  1. Vizio VTAB1008 Wi-Fi Antenna Replacement, Vizio VTAB1008 Back Cover Removal: passo 1, immagine 1 di 2 Vizio VTAB1008 Wi-Fi Antenna Replacement, Vizio VTAB1008 Back Cover Removal: passo 1, immagine 2 di 2
    • Carefully slide the heavy duty opening tool between the gap on the side of the device with no buttons.
    • Do not insert the opening tool too far into the tablet as this can damage connectors close to edges of the cover.
    • The angled tip of the opening tool can be wedged into the device by pressing on the back of the opening tool with the thumb. Move the opening tool in a sliding motion to ensure all tabs separate.
    • Corner tabs may require a more forceful prying tool. If needed, carefully insert the metal prying tool into corners to separate the tabs.
  2. Vizio VTAB1008 Wi-Fi Antenna Replacement: passo 2, immagine 1 di 1
    • Look into the tablet for loose connectors.
    • There are three loose connectors: one for the screen, one for the digitizer, and one for the motherboard. They are held in place by the pressure of the backing and screen assemblies.
    • Flip the backing from the button-less side over, being careful not to separate the ribbon connector from the display screen.
  3. Vizio VTAB1008 Wi-Fi Antenna Replacement, Wi-Fi Antenna: passo 3, immagine 1 di 3 Vizio VTAB1008 Wi-Fi Antenna Replacement, Wi-Fi Antenna: passo 3, immagine 2 di 3 Vizio VTAB1008 Wi-Fi Antenna Replacement, Wi-Fi Antenna: passo 3, immagine 3 di 3
    • Using the blue spudger/prying tool remove antenna connectors by prying them up from the motherboard.
  4. Vizio VTAB1008 Wi-Fi Antenna Replacement: passo 4, immagine 1 di 3 Vizio VTAB1008 Wi-Fi Antenna Replacement: passo 4, immagine 2 di 3 Vizio VTAB1008 Wi-Fi Antenna Replacement: passo 4, immagine 3 di 3
    • Remove connectors from the back cover by gently prying.
    • Connectors are glued down, but copper can be removed from the backing with light pulling.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 15
Tutti i Tempi: 240
