Salta al contenuto principale
Vizio VTAB1008 Charging Port Replacement
Cosa ti serve
  1. Vizio VTAB1008 Charging Port Replacement, Vizio VTAB1008 Back Cover Removal: passo 1, immagine 1 di 2 Vizio VTAB1008 Charging Port Replacement, Vizio VTAB1008 Back Cover Removal: passo 1, immagine 2 di 2
    • Carefully slide the heavy duty opening tool between the gap on the side of the device with no buttons.
    • Do not insert the opening tool too far into the tablet as this can damage connectors close to edges of the cover.
    • The angled tip of the opening tool can be wedged into the device by pressing on the back of the opening tool with the thumb. Move the opening tool in a sliding motion to ensure all tabs separate.
    • Corner tabs may require a more forceful prying tool. If needed, carefully insert the metal prying tool into corners to separate the tabs.
  2. Vizio VTAB1008 Charging Port Replacement: passo 2, immagine 1 di 1
    • Look into the tablet for loose connectors.
    • There are three loose connectors: one for the screen, one for the digitizer, and one for the motherboard. They are held in place by the pressure of the backing and screen assemblies.
    • Flip the backing from the button-less side over, being careful not to separate the ribbon connector from the display screen.
  3. Vizio VTAB1008 Charging Port Replacement, Charging Port: passo 3, immagine 1 di 3 Vizio VTAB1008 Charging Port Replacement, Charging Port: passo 3, immagine 2 di 3 Vizio VTAB1008 Charging Port Replacement, Charging Port: passo 3, immagine 3 di 3
    • Remove the motherboard by unscrewing the four securing screws with a J1 Phillip's head screwdriver.
    • 3 of the screws are clearly visible while the 4th is hidden by black tape on the upper left corner of the motherboard.
  4. Vizio VTAB1008 Charging Port Replacement: passo 4, immagine 1 di 3 Vizio VTAB1008 Charging Port Replacement: passo 4, immagine 2 di 3 Vizio VTAB1008 Charging Port Replacement: passo 4, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Remove both antenna connectors with a blue opening tool/tweezers.
  5. Vizio VTAB1008 Charging Port Replacement: passo 5, immagine 1 di 3 Vizio VTAB1008 Charging Port Replacement: passo 5, immagine 2 di 3 Vizio VTAB1008 Charging Port Replacement: passo 5, immagine 3 di 3
    • Remove the ribbon connector at the top of the motherboard using the opening tool.
  6. Vizio VTAB1008 Charging Port Replacement: passo 6, immagine 1 di 2 Vizio VTAB1008 Charging Port Replacement: passo 6, immagine 2 di 2
    • Remove the connector at the top of the motherboard by pulling the connector away from the motherboard with fingers or tweezers.
  7. Vizio VTAB1008 Charging Port Replacement: passo 7, immagine 1 di 3 Vizio VTAB1008 Charging Port Replacement: passo 7, immagine 2 di 3 Vizio VTAB1008 Charging Port Replacement: passo 7, immagine 3 di 3
    • Remove the connector at the side of the motherboard using the opening tool.
    • The connector is covered by a piece of black tape.
  8. Vizio VTAB1008 Charging Port Replacement: passo 8, immagine 1 di 2 Vizio VTAB1008 Charging Port Replacement: passo 8, immagine 2 di 2
    • Remove the red and black wire connector from the motherboard using either fingers or tweezers.
  9. Vizio VTAB1008 Charging Port Replacement: passo 9, immagine 1 di 3 Vizio VTAB1008 Charging Port Replacement: passo 9, immagine 2 di 3 Vizio VTAB1008 Charging Port Replacement: passo 9, immagine 3 di 3
    • Flip the motherboard over.
    • Directly underneath the USB Charging connector will be four solder points that need to be undone in order to remove the charging port.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 16
Tutti i Tempi: 1,265
