Salta al contenuto principale
Vizio SmartCast Tablet Remote XR6P Back Cover Replacement
Cosa ti serve
  1. Vizio SmartCast Tablet Remote XR6P Back Cover Replacement, Back Cover: passo 1, immagine 1 di 1
    • Obtain the black plastic spudger tool from the iFixit toolkit. Position the device as shown in the picture. Insert the flat end of the spudger directly in the space above the power button between the back cover and front screen.
  2. Vizio SmartCast Tablet Remote XR6P Back Cover Replacement: passo 2, immagine 1 di 1
    • Gently pry up on the plate with the spudger. You may hear some cracking noises as you work the spudger around your device, this is normal.
  3. Vizio SmartCast Tablet Remote XR6P Back Cover Replacement: passo 3, immagine 1 di 1
    • Pry around the edges of the tablet with your fingers until you have successfully removed the back of the device.
Conclusione
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 441
