Salta al contenuto principale
Vizio SmartCast Tablet Remote XR6M Micro-USB Port Replacement
Cosa ti serve
  1. Vizio SmartCast Tablet Remote XR6M Micro-USB Port Replacement, Micro-USB Port: passo 1, immagine 1 di 1
  2. Vizio SmartCast Tablet Remote XR6M Micro-USB Port Replacement: passo 2, immagine 1 di 2 Vizio SmartCast Tablet Remote XR6M Micro-USB Port Replacement: passo 2, immagine 2 di 2
    • Insert the tip of the nylon spudger under the black flap, and pull upwards toward yourself to disconnect it.
    • Be careful, as the flap can easily break off.
  3. Vizio SmartCast Tablet Remote XR6M Micro-USB Port Replacement: passo 3, immagine 1 di 3 Vizio SmartCast Tablet Remote XR6M Micro-USB Port Replacement: passo 3, immagine 2 di 3 Vizio SmartCast Tablet Remote XR6M Micro-USB Port Replacement: passo 3, immagine 3 di 3
    • Using the T-5 bit, unscrew the three 5mm screws, two attached to the green board, one attached to the black board.
  4. Vizio SmartCast Tablet Remote XR6M Micro-USB Port Replacement: passo 4, immagine 1 di 3 Vizio SmartCast Tablet Remote XR6M Micro-USB Port Replacement: passo 4, immagine 2 di 3 Vizio SmartCast Tablet Remote XR6M Micro-USB Port Replacement: passo 4, immagine 3 di 3
    • Using the nylon spudger, remove the silver cylindrical component followed by the green then black components
    • Be careful not to break the wires that are holding the three components together.
Conclusione
1Commento della guida
Is there a way to purchase a replacement battery?
Gasman - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 8
Tutti i Tempi: 505
