Salta al contenuto principale
Cosa ti serve
Questo smontaggio non è una guida di riparazione. Per riparare il tuo VOOM, usa il nostro manuale di assistenza.
  1. Vixt VOOM Disposable Teardown, Popping the cap: passo 1, immagine 1 di 3 Vixt VOOM Disposable Teardown, Popping the cap: passo 1, immagine 2 di 3 Vixt VOOM Disposable Teardown, Popping the cap: passo 1, immagine 3 di 3
    • The user manual had a nice x-ray view of the device.
    • The mouthpiece has a really good fit and required some force to remove. But you only need to pinch and pull, hard.
    • There is a fluid capturing pad in the mouthpiece and a silicone seal to prevent it from leaking, non of them was glued or secured in any noticeable way.
    Chiedi a FixBot
  2. Vixt VOOM Disposable Teardown, Undressing: passo 2, immagine 1 di 3 Vixt VOOM Disposable Teardown, Undressing: passo 2, immagine 2 di 3 Vixt VOOM Disposable Teardown, Undressing: passo 2, immagine 3 di 3
    • Nothing clipped or glued into place so far, just pinch and pull.
    • Nice little Li-po battery inside. Quite a waste to market this product as disposable with a rechargeable battery inside.
    Chiedi a FixBot
  3. Vixt VOOM Disposable Teardown, Cotton swabs: passo 3, immagine 1 di 3 Vixt VOOM Disposable Teardown, Cotton swabs: passo 3, immagine 2 di 3 Vixt VOOM Disposable Teardown, Cotton swabs: passo 3, immagine 3 di 3
    • The way the mouthpiece pops off and how the tank is built up it's definitely reusable, however the battery charge is a big problem.
    Chiedi a FixBot
  4. Vixt VOOM Disposable Teardown, Guts: passo 4, immagine 1 di 3 Vixt VOOM Disposable Teardown, Guts: passo 4, immagine 2 di 3 Vixt VOOM Disposable Teardown, Guts: passo 4, immagine 3 di 3
    • The tank was clipped on, but came loose fairly easy.
    • Couldn't remove the coil or the leads to the coil, and doing so would result in leakage due to the leads being sealed towards the tank with silicone goop.
    • The x-ray on the user manual indicated some more cotton between the tank/coil and cradle, but couldn't reach it.
    Chiedi a FixBot
  5. Vixt VOOM Disposable Teardown: passo 5, immagine 1 di 3 Vixt VOOM Disposable Teardown: passo 5, immagine 2 di 3 Vixt VOOM Disposable Teardown: passo 5, immagine 3 di 3
    • The chip seems to only be a switch to switch on and off the coil when you draw, and in doing so also activate the blue LED, nothing fancy here.
    • Modifying this to be rechargeable wouldn't be to hard if you get this far, since there is a lot of space in the battery cradle, for making contacts and such, but you'd need to get a charging circuit into it somewhere which might pose a problem.
    • Wouldn't recommend it though since the coil has an expected end of life after certain cycles, and isn't replaceable.
    Chiedi a FixBot
  6. Vixt VOOM Disposable Teardown, Laid to bare: passo 6, immagine 1 di 1
    • All parts (that i could take apart) in one picture.
    • My thoughts. All in all, this is a very wasteful product marketed as disposable, not only does it contain a poisonous concentration of nicotine, it also houses a rechargeable battery that you can't really recharge in any easy way. The reusable model is a a few extra bucks but you can recharge it, and replace the battery if need be.
    Chiedi a FixBot
David
Membro da: 08/21/11
963 Reputazione
4 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 2
Ultimi 7 giorni: 9
Ultimi 30 giorni: 67
Tutti i Tempi: 3,362
