Salta al contenuto principale
Vivotek FD8169 Motherboard Replacement
Cosa ti serve
  1. Vivotek FD8169 Motherboard Replacement, Dome Cover: passo 1, immagine 1 di 1
    • Loosen the outside screw.
  2. Vivotek FD8169 Motherboard Replacement: passo 2, immagine 1 di 1
    • Press down on the side button, and lift up the top dome.
  3. Vivotek FD8169 Motherboard Replacement, Camera Module: passo 3, immagine 1 di 1
    • Remove three screws that connect the camera base to the motherboard using a Phillips #1 screwdriver.
  4. Vivotek FD8169 Motherboard Replacement: passo 4, immagine 1 di 1
    • Lift off the camera base from the motherboard.
  5. Vivotek FD8169 Motherboard Replacement: passo 5, immagine 1 di 1
    • Unscrew the cord from the motherboard.
    • Unplug the remaining connection.
  6. Vivotek FD8169 Motherboard Replacement: passo 6, immagine 1 di 1
    • Unscrew the camera from the camera base with a hex screwdriver on both sides.
  7. Vivotek FD8169 Motherboard Replacement: passo 7, immagine 1 di 1
    • Pull the camera out from the camera base.
  8. Vivotek FD8169 Motherboard Replacement, Motherboard: passo 8, immagine 1 di 1
    • Once the camera module is removed, unscrew the two remaining screws which attach the motherboard to the backplate.
  9. Vivotek FD8169 Motherboard Replacement: passo 9, immagine 1 di 1
    • Once the screws are gone, lift the faulty motherboard and replace with a new one.
Conclusione
Artem Dudko
Membro da: 10/18/21
135 Reputazione
1 Guida realizzata
UMass Dartmouth, Team 1-6, Simcock Fall 2021 Membro di UMass Dartmouth, Team 1-6, Simcock Fall 2021
UMASSD-SIMCOCK-F21S1G6
4 Membri
4 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 19
Tutti i Tempi: 245
