Introduzione
The Vivo X7 Plus is hard to open and has a single unit display, but is moderately repairable due to its accessible battery. The phone ultimately earns a 7 out of 10 on the repairability scale.
Ricambi
Nessuna parte specificata.
Motherboard is next to come out.
Once the motherboard is removed, the rear-facing camera can be removed. Also the rubber bumper on the flash/proximity sensor portion of the main board.
The final components off of the display assembly are the vibrator and speaker.
Last-out display that is fused and mounted to a frame means a cracked screen is a time-consuming, expensive repair.
The Vivo X7 Plus earns a 7 out of 10 on our repairability scale (10 is the easiest to repair):
Battery is fairly easily accessible and removable.
Parts could be more modular, especially mechanical/high wear components.
The opening procedure is very tough, but easier than on the smaller model.
The single unit display assembly is annoying to reach, and will be a costly part.
Manufacturer does not provide user-accessible repair documentation.
Altre 9 persone hanno completato questa guida.
