Salta al contenuto principale
Vivitar Vivicam T027 Screen Replacement
Cosa ti serve
  1. Vivitar Vivicam T027 Screen Replacement, Screen: passo 1, immagine 1 di 2 Vivitar Vivicam T027 Screen Replacement, Screen: passo 1, immagine 2 di 2
    • Remove the 3 mm screws on the sides of the camera, using a Phillips #00 screwdriver.
  2. Vivitar Vivicam T027 Screen Replacement: passo 2, immagine 1 di 1
    • Remove the sticker on the top of the camera. This sticker covers a screw.
    • Remove five screws on the sides of the camera, including the screw under the sticker.
  3. Vivitar Vivicam T027 Screen Replacement: passo 3, immagine 1 di 2 Vivitar Vivicam T027 Screen Replacement: passo 3, immagine 2 di 2
    • Separate the front piece of the camera from the back to reveal the motherboard.
  4. Vivitar Vivicam T027 Screen Replacement: passo 4, immagine 1 di 1
    • Remove the plastic silver strip from the front case of the camera.
  5. Vivitar Vivicam T027 Screen Replacement: passo 5, immagine 1 di 1
    • Remove the three 2 mm screws holding in the gray plastic cover, using a Phillips #00 screwdriver.
  6. Vivitar Vivicam T027 Screen Replacement: passo 6, immagine 1 di 1
    • Remove the black plastic cover to reveal the newly exposed screen.
  7. Vivitar Vivicam T027 Screen Replacement: passo 7, immagine 1 di 2 Vivitar Vivicam T027 Screen Replacement: passo 7, immagine 2 di 2
    • Carefully remove the gold film from the screen with a plastic opening tool.
    • Gently pull the screen off the camera.
Conclusione
Marist, Team 15-13, Laflen Spring 2015 Membro di Marist, Team 15-13, Laflen Spring 2015
MARS-LAFLEN-S15S15G13
4 Membri
3 Guide realizzate
2 Commenti
Any heat required for this? How would I tap into the a/v feed from a digital camera to extend the screen? Data output to the sd card or usb?
Scott Haddox - Replica
How much would a screen replacement for a Vivitar Vivicam s124
SavageDoll Face - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 19
Tutti i Tempi: 845
