Salta al contenuto principale
Vivitar DVR 781HD Front Case Replacement
Cosa ti serve
  1. Vivitar DVR 781HD Front Case Replacement, Front Case: passo 1, immagine 1 di 3 Vivitar DVR 781HD Front Case Replacement, Front Case: passo 1, immagine 2 di 3 Vivitar DVR 781HD Front Case Replacement, Front Case: passo 1, immagine 3 di 3
    • Begin with the camcorder lens up on a clear working surface.
    • Remove the two 4mm Phillips #1 screws holding the switch plate in place. Rotate the device 180 degrees and repeat for the screws on the opposite side.
  2. Vivitar DVR 781HD Front Case Replacement: passo 2, immagine 1 di 1
    • Slide the plastic opening tool into the seam between the front and back sections of the case and apply a small amount of force to pop the case open.
  3. Vivitar DVR 781HD Front Case Replacement: passo 3, immagine 1 di 3 Vivitar DVR 781HD Front Case Replacement: passo 3, immagine 2 di 3 Vivitar DVR 781HD Front Case Replacement: passo 3, immagine 3 di 3
    • Move the plastic opening tool around the seam and apply force at each step to separate the front plate from the back plate and motherboard.
    • The battery is held to the front half of the case with double-sided tape. Peel it up with a finger, being careful not to damage the battery.
Conclusione
Jordan Baum
Membro da: 02/13/16
355 Reputazione
2 Guide realizzate
IUPUI, Team 54-6, Wilson Spring 2016 Membro di IUPUI, Team 54-6, Wilson Spring 2016
IUPUI-WILSON-S16S54G6
3 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 16
Tutti i Tempi: 292
