Salta al contenuto principale
Visual Land Prestige Elite 9Q LCD Screen Replacement
Cosa ti serve
  1. Visual Land Prestige Elite 9Q LCD Screen Replacement, LCD Screen: passo 1, immagine 1 di 1
    • Using the large plastic opening tool, start along a side of the device and apply light pressure in the seam between the top and bottom outer covers.
    • Maneuver the smaller plastic opening tool at the spot of the large opening tool and slowly slide along the edge.
    • You should feel each plastic connections begin to loosen.
  2. Visual Land Prestige Elite 9Q LCD Screen Replacement: passo 2, immagine 1 di 1
    • Move tool around each connection, and continue around the device until all connections have been loosened.
    • The user risks damaging the connections if they slide across to fast.
  3. Visual Land Prestige Elite 9Q LCD Screen Replacement: passo 3, immagine 1 di 3 Visual Land Prestige Elite 9Q LCD Screen Replacement: passo 3, immagine 2 di 3 Visual Land Prestige Elite 9Q LCD Screen Replacement: passo 3, immagine 3 di 3
    • Once all connections have been loosened and using a soft surface, place the device onto its screen and lift gently on the outer casing.
    • Open the casing and lay as shown keeping the speaker wires loose.
    • The highlighted areas represent connections to disassemble.
  4. Visual Land Prestige Elite 9Q LCD Screen Replacement: passo 4, immagine 1 di 2 Visual Land Prestige Elite 9Q LCD Screen Replacement: passo 4, immagine 2 di 2
    • Using hook tweezers and a spudger, gently remove the glued speaker away from the casing.
    • The tweezers can damage the speaker.
    • The speaker is still connected to the motherboard with wire, so be cautious during this process.
  5. Visual Land Prestige Elite 9Q LCD Screen Replacement: passo 5, immagine 1 di 2 Visual Land Prestige Elite 9Q LCD Screen Replacement: passo 5, immagine 2 di 2
    • Using wide-tip tweezers, gently remove the three pieces of tape attached to battery
    • The battery is still connected to the circuit board, and do not damage the tape as it holds the battery to the rest of the device.
  6. Visual Land Prestige Elite 9Q LCD Screen Replacement: passo 6, immagine 1 di 1
    • Next remove the WiFi module from the bottom of the device. This is simply pealed off.
  7. Visual Land Prestige Elite 9Q LCD Screen Replacement: passo 7, immagine 1 di 2 Visual Land Prestige Elite 9Q LCD Screen Replacement: passo 7, immagine 2 di 2
    • Gently remove tape from circuit board, and disconnect the ZIF (zero insertion force) connectors for the front panel and LCD screen.
    • Use tweezers to lift up the black hinged lock on top of the ZIF connector.
  8. Visual Land Prestige Elite 9Q LCD Screen Replacement: passo 8, immagine 1 di 1
    • Use pointed hook tweezers to gently lift up front facing camera by grabbing the padding on back of camera.
    • Located on corner of tablet
    • Do not grab camera lens, tweezers may damage lens.
  9. Visual Land Prestige Elite 9Q LCD Screen Replacement: passo 9, immagine 1 di 1
    • Use pointed hook tweezers to gently remove rear facing camera by grabbing the corner of camera casing.
    • Located above charger jack.
    • Do not grab camera lens, tweezers will damage camera lens.
  10. Visual Land Prestige Elite 9Q LCD Screen Replacement: passo 10, immagine 1 di 1
    • Use pointed hook tweezers to gently flip up hinged ZIF connector.
    • After ZIF connector is flipped up, remove camera module.
  11. Visual Land Prestige Elite 9Q LCD Screen Replacement: passo 11, immagine 1 di 2 Visual Land Prestige Elite 9Q LCD Screen Replacement: passo 11, immagine 2 di 2
    • These are the three screws holding the circuit board.
    • Use J00 or PH00 to remove the three screws.
  12. Visual Land Prestige Elite 9Q LCD Screen Replacement: passo 12, immagine 1 di 1
    • Make space in work area, and remove battery, circuit board, speaker, and wifi module as one from the LCD screen and front glass.
    • Handle carefully because battery speaker and wifi module are only connected by soldered connections.
  13. Visual Land Prestige Elite 9Q LCD Screen Replacement: passo 13, immagine 1 di 1
    • Shown are all the clips that hold the LCD screen to the front glass.
  14. Visual Land Prestige Elite 9Q LCD Screen Replacement: passo 14, immagine 1 di 1
    • Start in the corner and pull back one of the black tabs. At the same time try to get under the screen with the tweezers.
    • Once one side is pulled up the rest should come off relatively easily.
  15. Visual Land Prestige Elite 9Q LCD Screen Replacement: passo 15, immagine 1 di 1
    • After detaching front glass from LCD Screen, lay LCD screen down on white styrofoam side and this is what it will look like.
    • Do not place screen down on black side to prevent damaging screen
  16. Visual Land Prestige Elite 9Q LCD Screen Replacement: passo 16, immagine 1 di 1
    • After removing LCD screen this is what the front glass component will look like.
    • At this point a better assessment can be made of whether the LCD screen is bad or the front glass is cracked.
Conclusione
Altre 2 persone hanno completato questa guida.
Aaron
Membro da: 07/19/16
316 Reputazione
2 Guide realizzate
Un commento
Would this process work for the Prestige Elite 8qi as well?
Bill Shannon - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 10
Tutti i Tempi: 1,528
