Salta al contenuto principale
Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement
Cosa ti serve
  1. Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement, Digitizer / Front Screen: passo 1, immagine 1 di 2 Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement, Digitizer / Front Screen: passo 1, immagine 2 di 2
    • At the bottom of the tablet, remove the two 3.6mm screws with a Phillips #000 screwdriver.
  2. Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: passo 2, immagine 1 di 2 Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: passo 2, immagine 2 di 2
    • Wedge a plastic opening tool into the edges of the tablet to pry it open.
  3. Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: passo 3, immagine 1 di 3 Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: passo 3, immagine 2 di 3 Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: passo 3, immagine 3 di 3
    • Wedge a curved metal spudger under the speaker in order to remove it.
    • The speaker is held in place by an adhesive and can be difficult to remove.
  4. Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: passo 4, immagine 1 di 3 Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: passo 4, immagine 2 di 3 Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: passo 4, immagine 3 di 3
    • Use a Phillips #000 screwdriver to remove the two 3.6mm screws.
  5. Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: passo 5, immagine 1 di 3 Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: passo 5, immagine 2 di 3 Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: passo 5, immagine 3 di 3
    • Use a plastic opening tool to lift the black tab.
  6. Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: passo 6, immagine 1 di 2 Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: passo 6, immagine 2 di 2
    • Carefully lift and remove the ribbon cable from the black tab.
  7. Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: passo 7, immagine 1 di 2 Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: passo 7, immagine 2 di 2
    • Use a plastic opening tool to remove the camera.
  8. Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: passo 8, immagine 1 di 2 Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: passo 8, immagine 2 di 2
    • Use a Phillips #000 screwdriver to remove the 3.6mm screw.
  9. Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: passo 9, immagine 1 di 3 Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: passo 9, immagine 2 di 3 Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: passo 9, immagine 3 di 3
    • Lift the tape holding down the battery.
  10. Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: passo 10, immagine 1 di 2 Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: passo 10, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    Plastic Cards
    $2.99
  11. Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: passo 11, immagine 1 di 3 Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: passo 11, immagine 2 di 3 Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: passo 11, immagine 3 di 3
  12. Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: passo 12, immagine 1 di 2 Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: passo 12, immagine 2 di 2
  13. Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: passo 13, immagine 1 di 3 Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: passo 13, immagine 2 di 3 Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: passo 13, immagine 3 di 3
  14. Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: passo 14, immagine 1 di 1
    • Safely remove the battery and motherboard from the tablet.
  15. Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: passo 15, immagine 1 di 3 Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: passo 15, immagine 2 di 3 Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: passo 15, immagine 3 di 3
    • Lift the tape on the sides.
  16. Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: passo 16, immagine 1 di 3 Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: passo 16, immagine 2 di 3 Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: passo 16, immagine 3 di 3
    • Use a Phillips #000 screwdriver to remove the three 2.5mm screws.
  17. Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: passo 17, immagine 1 di 3 Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: passo 17, immagine 2 di 3 Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: passo 17, immagine 3 di 3
    • Wedge a metal spudger underneath the LCD screen to remove it.
  18. Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: passo 18, immagine 1 di 1
    • Replace the front screen to replace the digitizer.
Conclusione
UC Davis, Team 2-1, Oliver Fall 2016 Membro di UC Davis, Team 2-1, Oliver Fall 2016
UCD-OLIVER-F16S2G1
5 Membri
12 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 4
Tutti i Tempi: 639
