Salta al contenuto principale
Visual Land Prestige 7L Front Facing Camera Replacement
Cosa ti serve
  1. Visual Land Prestige 7L Front Facing Camera Replacement, Back Panel: passo 1, immagine 1 di 2 Visual Land Prestige 7L Front Facing Camera Replacement, Back Panel: passo 1, immagine 2 di 2
    • Remove the two 8mm Phillips Head screws located at the bottom of your device.
  2. Visual Land Prestige 7L Front Facing Camera Replacement: passo 2, immagine 1 di 3 Visual Land Prestige 7L Front Facing Camera Replacement: passo 2, immagine 2 di 3 Visual Land Prestige 7L Front Facing Camera Replacement: passo 2, immagine 3 di 3
    • Insert the spudger between the two pieces of the case around the media ports and pry them apart.
    • We found the best way to get the spudger inside the case was to insert in into the SD card slot. Be sure to only insert the spudger a shallow amount and be careful not to damage any of the inside of the device.
    • Finish unsnapping each plastic piece holding the device together along the bottom.
  3. Visual Land Prestige 7L Front Facing Camera Replacement: passo 3, immagine 1 di 3 Visual Land Prestige 7L Front Facing Camera Replacement: passo 3, immagine 2 di 3 Visual Land Prestige 7L Front Facing Camera Replacement: passo 3, immagine 3 di 3
    • Move the spudger down the rest of the case, separating each side, and finally the top.
    • Pull the back off and place it to the side.
    • Without a back panel for protection, be sure place your device on the table screen-side down to avoid damaging the internal circuitry.
  4. Visual Land Prestige 7L Front Facing Camera Replacement, Front Facing Camera: passo 4, immagine 1 di 2 Visual Land Prestige 7L Front Facing Camera Replacement, Front Facing Camera: passo 4, immagine 2 di 2
    • Remove the adhesive padding.
  5. Visual Land Prestige 7L Front Facing Camera Replacement: passo 5, immagine 1 di 2 Visual Land Prestige 7L Front Facing Camera Replacement: passo 5, immagine 2 di 2
    • Unclip the connector that attaches the camera to the motherboard.
    • For more information on unclipping connectors see this How To Guide
    • Do not pull on the camera until you're sure that it's unclipped, the gold connection will rip.
    • Gently pop the camera out of the connector and off the case.
Conclusione
Penn State, Team 2-25, Kaschak Winter 2015 Membro di Penn State, Team 2-25, Kaschak Winter 2015
PSU-KASCHAK-W15S2G25
4 Membri
4 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 273
