Salta al contenuto principale
Visual Land Prestige 7G Speaker Replacement
Cosa ti serve
  1. Visual Land Prestige 7G Speaker Replacement, Backplate: passo 1, immagine 1 di 2 Visual Land Prestige 7G Speaker Replacement, Backplate: passo 1, immagine 2 di 2
    • Lay your device face-down.
    • Use a Phillips #000 screwdriver to remove the two 4 mm screws next to the AUX port and microphone.
  2. Visual Land Prestige 7G Speaker Replacement: passo 2, immagine 1 di 1
    • Pry open the back-plate using a Jimmy.
    • Do this by inserting the tool into the fine thin line between the back-plate and screen at each corner of the device.
  3. Visual Land Prestige 7G Speaker Replacement: passo 3, immagine 1 di 2 Visual Land Prestige 7G Speaker Replacement: passo 3, immagine 2 di 2
    • Lift off the backplate using your hand.
    • If the backplate is stuck, repeat the previous step to ensure all the edges are free.
  4. Visual Land Prestige 7G Speaker Replacement, Speaker: passo 4, immagine 1 di 2 Visual Land Prestige 7G Speaker Replacement, Speaker: passo 4, immagine 2 di 2
    • Take the soldering gun and place it on the black and red wires to melt the soldered conncetions.
    • Remove the speaker.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 33
