Salta al contenuto principale
Introduzione
Use this guide to remove the belt that moves the Visioneer OneTouch 7400 USB sensor bar for repair or replacement.
Parti
Nessuna parte specificata.
  1. On the bottom of the scanner, remove the screw at the top left side.
    • On the bottom of the scanner, remove the screw at the top left side.
  2. Remove the rubber foot pad opposite the screw hole to expose a second screw hole. Remove the screw beneath the foot-pad.
    • Remove the rubber foot pad opposite the screw hole to expose a second screw hole.
    • Remove the screw beneath the foot-pad.
  3. Rotate the scanner so the screw hole is located on the top left hand side. Place the plastic opening tool between the top casement and bottom casement of scanner with the hook facing up. Gently pry the two casements apart beginning above the screw hole and working your way around.
    • Rotate the scanner so the screw hole is located on the top left hand side.
    • Place the plastic opening tool between the top casement and bottom casement of scanner with the hook facing up.
    • Gently pry the two casements apart beginning above the screw hole and working your way around.
    • Note that the top and bottom casings are held together by a series of 6 tabs. There is one tab on each of the long sides of the scanner approximately 6 inches in from the corners. There are two tabs on each of the short sides of the scanner approximately 2.3 inches in from the corners. Use the spudger to unhook the tab from the top casement.
  4. Separate the two casement pieces.
    • Separate the two casement pieces.
  5. Batterie per PC portatili
    Una soluzione semplice per un grande aumento di potenza.
    Acquista ora
    Acquista ora
  6. Remove the screw holding the tension spring in place.
    • Remove the screw holding the tension spring in place.
  7. Use the plastic opening tool to lift up the tension spring.
    • Use the plastic opening tool to lift up the tension spring.
    • Be careful. The spring will fly.
  8. Remove the belt from the spool.
    • Remove the belt from the spool.
    • The spool is a loose piece; don't lose it.
  9. Loosen the belt enough to turn over the sensor bar.
    • Loosen the belt enough to turn over the sensor bar.
  10. With the sensor bar turned upside down, remove the screw in the middle of the bar. Lift off the metal plate if it does not come away with the screw.
    • With the sensor bar turned upside down, remove the screw in the middle of the bar.
    • Lift off the metal plate if it does not come away with the screw.
  11. Carefully lift the belt out of the groove in the sensor bar to remove.
    • Carefully lift the belt out of the groove in the sensor bar to remove.
Conclusione
Jena
Membro da: 18/10/2013
608 Reputazione
6 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 159
