Introduzione
Use this guide to remove the belt that moves the Visioneer OneTouch 7400 USB sensor bar for repair or replacement.
Parti
Nessuna parte richiesta.
On the bottom of the scanner, remove the screw at the top left side.
  • On the bottom of the scanner, remove the screw at the top left side.
Aggiungi Commento
Remove the rubber foot pad opposite the screw hole to expose a second screw hole.
  • Remove the rubber foot pad opposite the screw hole to expose a second screw hole.
  • Remove the screw beneath the foot-pad.
Aggiungi Commento
  • Rotate the scanner so the screw hole is located on the top left hand side.
  • Place the plastic opening tool between the top casement and bottom casement of scanner with the hook facing up.
  • Gently pry the two casements apart beginning above the screw hole and working your way around.
  • Note that the top and bottom casings are held together by a series of 6 tabs. There is one tab on each of the long sides of the scanner approximately 6 inches in from the corners. There are two tabs on each of the short sides of the scanner approximately 2.3 inches in from the corners. Use the spudger to unhook the tab from the top casement.
Aggiungi Commento
  • Separate the two casement pieces.
Aggiungi Commento
  • Remove the screw holding the tension spring in place.
Aggiungi Commento
  • Use the plastic opening tool to lift up the tension spring.
    • Be careful. The spring will fly.
Aggiungi Commento
  • Remove the belt from the spool.
    • The spool is a loose piece; don't lose it.
Aggiungi Commento
  • Loosen the belt enough to turn over the sensor bar.
Aggiungi Commento
  • With the sensor bar turned upside down, remove the screw in the middle of the bar.
  • Lift off the metal plate if it does not come away with the screw.
Aggiungi Commento
  • Carefully lift the belt out of the groove in the sensor bar to remove.
Aggiungi Commento
Conclusione
Jena
Membro da: 18/10/2013
608 Reputazione
6 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 149
