Salta al contenuto principale
Aggiusta la tua roba
Diritto alla Riparazione
Store
Parti
Nessuna parte specificata.
  1. Remove nine 12mm Phillips screws from the upper back panel. Remove three 12mm Phillips screws inset under the back panel.
    • Remove nine 12mm Phillips screws from the upper back panel.
    • Remove three 12mm Phillips screws inset under the back panel.
    • As soon as the screws are removed, the panel will fall freely.
    • When replacing the twelve 12mm Phillips screws, do not tighten the fasteners until all twelve screws have been loosely fitted back onto the cooler. This will ensure the flimsy metal casing will not warp.
  2. Power Cord Fastener
    • Power Cord Fastener
    • Ground
    • Motherboard
    • Heat Sink Fan
    • Heat Sink
  3. SKIP THE UPGRADE
    Save by fixing with an all-in-one kit.
    Shop iPhone Fix Kits
    SKIP THE UPGRADE
  4. Remove two 7mm Hex Nuts. Clearance is minimal and these screws are very tight. You will likely need a socket wrench to avoid stripping. If the white plastic components stick, pry them apart with a metal spudger. Don't pull on the power cord to get plastic pieces to separate.
    • Remove two 7mm Hex Nuts.
    • Clearance is minimal and these screws are very tight. You will likely need a socket wrench to avoid stripping.
    • If the white plastic components stick, pry them apart with a metal spudger. Don't pull on the power cord to get plastic pieces to separate.
  5. Remove one 12mm Phillips screw securing ground. Remove one 12mm Phillips screw securing ground.
    • Remove one 12mm Phillips screw securing ground.
  6. Remove power cable from motherboard. Pinch cable connector to release it from the motherboard, then pull. Pinch cable connector to release it from the motherboard, then pull.
    • Remove power cable from motherboard.
    • Pinch cable connector to release it from the motherboard, then pull.
  7. Your power cord is removed.
    • Your power cord is removed.
Conclusione
Jeff Snyder
Membro da: 07/02/2013
6.392 Reputazione
4 Guide realizzate
iFixit Membro di iFixit
Community
128 Membri
13.048 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 592
