Introduzione
If your humidifier is not producing any mist, then there may be a problem with the ultrasonic mist maker. If the mist maker is malfunctioning, it will need to be replaced.
Cosa ti serve
Orient the device so the nozzle is facing the ceiling.
Twist off the primary water holding cap.
Remove the three screws from the base of the device using a T20 Torx screwdriver.
Remove the base of the humidifier to access the components.
Quasi finito!
Conclusione
