Salta al contenuto principale
Vicks FilterFree Plus Ultrasonic Mist Maker Replacement
Cosa ti serve
  1. Vicks FilterFree Plus Ultrasonic Mist Maker Replacement, Tank Cap: passo 1, immagine 1 di 1
    • Ensure the device is clear of water before disassembling.
    • Orient the device so the nozzle is facing the ceiling.
    • Twist off the primary water holding cap.
  2. Vicks FilterFree Plus Ultrasonic Mist Maker Replacement: passo 2, immagine 1 di 2 Vicks FilterFree Plus Ultrasonic Mist Maker Replacement: passo 2, immagine 2 di 2
    • Place the device upside down so that the tank cap is facing you.
    • Use your hands to twist the tank cap and remove it from the device.
  3. Vicks FilterFree Plus Ultrasonic Mist Maker Replacement, Ultrasonic Mist Maker: passo 3, immagine 1 di 2 Vicks FilterFree Plus Ultrasonic Mist Maker Replacement, Ultrasonic Mist Maker: passo 3, immagine 2 di 2
    • Remove the three screws from the base of the device using a T20 Torx screwdriver.
    • Remove the base of the humidifier to access the components.
  4. Vicks FilterFree Plus Ultrasonic Mist Maker Replacement: passo 4, immagine 1 di 2 Vicks FilterFree Plus Ultrasonic Mist Maker Replacement: passo 4, immagine 2 di 2
    • Gently remove the inner shield for the primary board to access the wiring for the humidifier.
  5. Vicks FilterFree Plus Ultrasonic Mist Maker Replacement: passo 5, immagine 1 di 3 Vicks FilterFree Plus Ultrasonic Mist Maker Replacement: passo 5, immagine 2 di 3 Vicks FilterFree Plus Ultrasonic Mist Maker Replacement: passo 5, immagine 3 di 3
    • Remove the square heat shield by unscrewing the two screws using a Phillips #1 screwdriver.
    • Unclip the mist maker power cord.
  6. Vicks FilterFree Plus Ultrasonic Mist Maker Replacement: passo 6, immagine 1 di 3 Vicks FilterFree Plus Ultrasonic Mist Maker Replacement: passo 6, immagine 2 di 3 Vicks FilterFree Plus Ultrasonic Mist Maker Replacement: passo 6, immagine 3 di 3
    • Remove the triangle shaped heat shield by unscrewing the three screws using a Phillips #1 screwdriver.
    • Take note of the mist maker's orientation for reassembly.
    • Remove the mist maker from the device.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 13
Tutti i Tempi: 387
