Introduzione
If you need to reinstall the power cord access the bottom hub of the device. For this guide, you will need a standard Philips head and a T20 screwdriver. You will not need to do any difficult steps, but ensure you handle the motherboard with care.
Cosa ti serve
Orient the device so the nozzle is facing the ceiling.
Twist off the primary water holding cap.
Remove the three screws from the base of the device using a T20 Torx screwdriver.
Remove the base of the humidifier to access the components.
