Salta al contenuto principale
VersaMed iVent 201 Power Pack Replacement
Cosa ti serve
  1. VersaMed iVent 201 Power Pack Replacement, Power Pack: passo 1, immagine 1 di 1
    • Remove the four 3mm x 20mm Phillips screws located on the corners of the power pack.
  2. VersaMed iVent 201 Power Pack Replacement: passo 2, immagine 1 di 1
    • Pull the power pack from the compartment using black handle.
  3. VersaMed iVent 201 Power Pack Replacement: passo 3, immagine 1 di 1
    • Remove the five 3mm x 10mm Phillips screws and washers from the back of the power pack. Lift off the cover after.
  4. VersaMed iVent 201 Power Pack Replacement: passo 4, immagine 1 di 1
    • Turn the battery pack upside down and take the battery out of the casing.
    • When reassembling, listen for the sound of the cooling fan for confirmation that the connection was successful.
  5. VersaMed iVent 201 Power Pack Replacement: passo 5, immagine 1 di 1
    • Remove the two spade connectors using pliers.
    • When assembling the power pack, MAKE SURE to connect the red wire to the positive terminal and the black wire to the negative terminal of the battery.
Conclusione
To reassemble your device, follow these instructions in reverse order. Caution: MAKE SURE THE RED WIRE IS CONNECTED TO THE POSITIVE TERMINAL AND THE BLACK WIRE IS CONNECTED TO THE NEGATIVE.
Jeffrey Yin
Membro da: 04/09/20
265 Reputazione
2 Guide realizzate
Cal Poly, Team S7-G17, Paton Spring 2020 Membro di Cal Poly, Team S7-G17, Paton Spring 2020
CPSU-PATON-S20S7G17
2 Membri
2 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 10
Tutti i Tempi: 284
