Salta al contenuto principale
Verizon M1424WR Motherboard Replacement
Cosa ti serve
  1. Verizon M1424WR Motherboard Replacement, Motherboard: passo 1, immagine 1 di 1
    • Flip the device so that the bottom is facing up.
  2. Verizon M1424WR Motherboard Replacement: passo 2, immagine 1 di 3 Verizon M1424WR Motherboard Replacement: passo 2, immagine 2 di 3 Verizon M1424WR Motherboard Replacement: passo 2, immagine 3 di 3
    • Warning: The design and location of the plastic clips holding this shroud make it extremely difficult to release. Take your time and use a second pry tool if necessary.
    • Insert the plastic-opening tool under the silver labeled casing.
    • Carefully pry at different intervals around the silver labeled casing to separate the silver casing from the top and bottom casing.
  3. Verizon M1424WR Motherboard Replacement: passo 3, immagine 1 di 2 Verizon M1424WR Motherboard Replacement: passo 3, immagine 2 di 2
    • Unscrew the five 10-mm screws on the bottom of the router using a Phillips #0 screwdriver.
  4. Verizon M1424WR Motherboard Replacement: passo 4, immagine 1 di 2 Verizon M1424WR Motherboard Replacement: passo 4, immagine 2 di 2
    • Use a plastic-opening tool and pry the top casing from the bottom casing to expose the circuit board in the bottom half of the device.
  5. Verizon M1424WR Motherboard Replacement: passo 5, immagine 1 di 3 Verizon M1424WR Motherboard Replacement: passo 5, immagine 2 di 3 Verizon M1424WR Motherboard Replacement: passo 5, immagine 3 di 3
    • Locate the two 10-mm screws on either side of the circuit board.
    • Unscrew the two 10-mm screws using a Phillips #0 screwdriver.
    • Keep track of the red rubber washer you remove from underneath one of the screws.
  6. Verizon M1424WR Motherboard Replacement: passo 6, immagine 1 di 1
    • Lift the front of the circuit board up from the bottom casing.
  7. Verizon M1424WR Motherboard Replacement: passo 7, immagine 1 di 1
    • Pull the circuit board towards you until it is separate from the bottom casing.
Conclusione
Altre 2 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 13
Tutti i Tempi: 836
