Salta al contenuto principale
Verizon Ellipsis Jetpack MHS800L Screen Replacement
Cosa ti serve
  1. Verizon Ellipsis Jetpack MHS800L Screen Replacement, Plastic Case: passo 1, immagine 1 di 3 Verizon Ellipsis Jetpack MHS800L Screen Replacement, Plastic Case: passo 1, immagine 2 di 3 Verizon Ellipsis Jetpack MHS800L Screen Replacement, Plastic Case: passo 1, immagine 3 di 3
    • Remove the SIM card, that is located on top of the Jetpack.
  2. Verizon Ellipsis Jetpack MHS800L Screen Replacement: passo 2, immagine 1 di 3 Verizon Ellipsis Jetpack MHS800L Screen Replacement: passo 2, immagine 2 di 3 Verizon Ellipsis Jetpack MHS800L Screen Replacement: passo 2, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    Phillips #00 Screwdriver
    $5.49
    • With the device on its back and the label facing you, remove the rubber screw cover on the top left corner of the device.
    • Under the rubber circle, remove the 1.25 mm screw using a Phillips #00 Screwdriver.
    • You may need to peel back a piece of double sided tape covering the screw hole.
  3. Verizon Ellipsis Jetpack MHS800L Screen Replacement: passo 3, immagine 1 di 1
    • Remove three 1.25 mm screws.
  4. Verizon Ellipsis Jetpack MHS800L Screen Replacement: passo 4, immagine 1 di 1
    iFixit Opening Picks (Set of 6)
  5. Verizon Ellipsis Jetpack MHS800L Screen Replacement: passo 5, immagine 1 di 1
    • Once the cover is off, this is what your device will look like.
  6. Verizon Ellipsis Jetpack MHS800L Screen Replacement, Battery: passo 6, immagine 1 di 2 Verizon Ellipsis Jetpack MHS800L Screen Replacement, Battery: passo 6, immagine 2 di 2
    • Once you have the case off of your device gently pull your battery away from the device.
    • Do not attempt to completely remove the battery, as it is still attached to the motherboard by wires.
  7. Verizon Ellipsis Jetpack MHS800L Screen Replacement: passo 7, immagine 1 di 2 Verizon Ellipsis Jetpack MHS800L Screen Replacement: passo 7, immagine 2 di 2
    • With a pair of Tweezers remove the yellow tape covering the battery wires.
  8. Verizon Ellipsis Jetpack MHS800L Screen Replacement: passo 8, immagine 1 di 1
    • After removing the tape you may use the Tweezers to remove the wiring harness from the circuit board.
    • Do not squeeze the wires to hard you may damage them and cause a short.
  9. Verizon Ellipsis Jetpack MHS800L Screen Replacement: passo 9, immagine 1 di 1
    • You may now replace the battery in your Verizon Ellipsis Jetpack MHS800L.
  10. Verizon Ellipsis Jetpack MHS800L Screen Replacement, Screen: passo 10, immagine 1 di 3 Verizon Ellipsis Jetpack MHS800L Screen Replacement, Screen: passo 10, immagine 2 di 3 Verizon Ellipsis Jetpack MHS800L Screen Replacement, Screen: passo 10, immagine 3 di 3
    • Locate the LCD screen cable and unlatch the harness connection form the circuit board.
  11. Verizon Ellipsis Jetpack MHS800L Screen Replacement: passo 11, immagine 1 di 2 Verizon Ellipsis Jetpack MHS800L Screen Replacement: passo 11, immagine 2 di 2
    • Using the Tweezers gently coax the display data cable out of circuit board connector.
    • Do not squeeze the display data cable to hard you may damage it and cause a short.
  12. Verizon Ellipsis Jetpack MHS800L Screen Replacement: passo 12, immagine 1 di 2 Verizon Ellipsis Jetpack MHS800L Screen Replacement: passo 12, immagine 2 di 2
    • Gently insert the Tweezers underneath the LCD screen and lift the LCD screen off of the circuit board.
Conclusione
IUPUI, Team 3-3, Baechle Spring 2016 Membro di IUPUI, Team 3-3, Baechle Spring 2016
IUPUI-BAECHLE-S16S3G3
4 Membri
6 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 8
Tutti i Tempi: 2,269
