Salta al contenuto principale
Verizon Ellipsis 8 Button Replacement
Cosa ti serve
  1. Verizon Ellipsis 8  Button Replacement, Power/Volume Buttons: passo 1, immagine 1 di 1
    • First, use a plastic opening tool in order to slowly pry across the crevasse on the side of the device. This plastic back of the device will un-click during this process and you will remove the back piece.
  2. Verizon Ellipsis 8  Button Replacement: passo 2, immagine 1 di 1
    • Using your fingers, firmly grasp either the power button or the volume buttons and remove them, releasing the clasps that hold the buttons into place.
  3. Verizon Ellipsis 8  Button Replacement: passo 3, immagine 1 di 1
    • Now, using your fingers replace the buttons that you have removed in the previous step with the new functioning buttons. Enter the button in at an angle and press it into place, clicking it into the open slot. To reassemble your device, follow these instructions in reverse order.
Conclusione
Jack
Membro da: 02/06/19
610 Reputazione
3 Guide realizzate
UC Davis, Team S18-G6, Lore Winter 2019 Membro di UC Davis, Team S18-G6, Lore Winter 2019
UCD-LORE-W19S18G6
3 Membri
3 Guide realizzate
1Commento della guida
where can i purchase replacement buttons for this device? anyone know? Thanks!!!
Broadcast Depth - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 11
Tutti i Tempi: 596
