Salta al contenuto principale
Verizon Ellipsis 7 Screen Replacement
Cosa ti serve
  1. Verizon Ellipsis 7 Screen Replacement, Charging Port: passo 1, immagine 1 di 3 Verizon Ellipsis 7 Screen Replacement, Charging Port: passo 1, immagine 2 di 3 Verizon Ellipsis 7 Screen Replacement, Charging Port: passo 1, immagine 3 di 3
    • Hold down the power button until the screen goes black to turn off the device.
    • Remove the SIM card from the device to prevent damage.
    • To remove the SIM card, open the SIM card cover on the side of the device.
    • Push SIM card in and pull it out after hearing a click.
  2. Verizon Ellipsis 7 Screen Replacement: passo 2, immagine 1 di 2 Verizon Ellipsis 7 Screen Replacement: passo 2, immagine 2 di 2
    • Take off the back panel.
    • Pry open the back cover carefully with a plastic opening tool.
    • Use the opening tool to disconnect the cover completely. Do not attempt to pry the back cover off with your hands.
    • Be sure to pry open all sides of the device. Attempting to take off the back cover when part of it is attached may snap the cover.
  3. Verizon Ellipsis 7 Screen Replacement: passo 3, immagine 1 di 3 Verizon Ellipsis 7 Screen Replacement: passo 3, immagine 2 di 3 Verizon Ellipsis 7 Screen Replacement: passo 3, immagine 3 di 3
    • Remove the charging (micro-USB) port.
    • Unscrew the indicated screws using the Phillips #00 screwdriver.
    • The screws shown in the picture are the more common 4.76 mm.
    • Disconnect the ribbon cable connecting the charging port board to the motherboard using tweezers.
    • Use the tweezers to grab the sides of black, plastic connector. Do not grab from the wires or try to wedge it out from the bottom.
    • Be extremely careful when disconnecting the ribbon cable. It is very delicate.
  4. Verizon Ellipsis 7 Screen Replacement: passo 4, immagine 1 di 2 Verizon Ellipsis 7 Screen Replacement: passo 4, immagine 2 di 2
    • Remove the charging port board from the phone using tweezers.
    • Place the replacement charging port into the phone.
    • Be cautious when replacing the ribbon cable onto the new charging port board.
  5. Verizon Ellipsis 7 Screen Replacement, Speaker: passo 5, immagine 1 di 2 Verizon Ellipsis 7 Screen Replacement, Speaker: passo 5, immagine 2 di 2
    • Remove 2 screws from each speaker, 4 screws in total, using a Phillips #00 screwdriver.
  6. Verizon Ellipsis 7 Screen Replacement: passo 6, immagine 1 di 3 Verizon Ellipsis 7 Screen Replacement: passo 6, immagine 2 di 3 Verizon Ellipsis 7 Screen Replacement: passo 6, immagine 3 di 3
    • Using tweezers carefully lift the connector up to disconnect it from the motherboard.
    • Using tweezers carefully pull the speakers up and out of device.
  7. Verizon Ellipsis 7 Screen Replacement, Screen: passo 7, immagine 1 di 1
    • Use the tweezers to carefully disconnect the power cable bundle from the motherboard.
  8. Verizon Ellipsis 7 Screen Replacement: passo 8, immagine 1 di 2 Verizon Ellipsis 7 Screen Replacement: passo 8, immagine 2 di 2
    • Remove the 10 screws from the motherboard using a Phillips #0 screwdriver.
    • The screws shown in the first picture are the more common 4.76 mm.
    • The screw shown in the second picture is shorter, 3.175 mm, than the rest of the screws
  9. Verizon Ellipsis 7 Screen Replacement: passo 9, immagine 1 di 2 Verizon Ellipsis 7 Screen Replacement: passo 9, immagine 2 di 2
    • Remove the 5 antenna cable connectors from the motherboard using a spudger.
  10. Verizon Ellipsis 7 Screen Replacement: passo 10, immagine 1 di 3 Verizon Ellipsis 7 Screen Replacement: passo 10, immagine 2 di 3 Verizon Ellipsis 7 Screen Replacement: passo 10, immagine 3 di 3
    • Disconnect the two ZIF connectors that are connected to the motherboard with a spudger. Lift up the metal part of the connector and then pull the connector off of its port
    • Once disconnected pull away from its connector carefully with tweezers.
    • Once the connectors have been disconnected you can gently lift up on the motherboard to remove it from the device.
  11. Verizon Ellipsis 7 Screen Replacement: passo 11, immagine 1 di 2 Verizon Ellipsis 7 Screen Replacement: passo 11, immagine 2 di 2
    • Remove the motherboard from the tablet.
    • Use the spudger to disconnect the press lift connector.
  12. Verizon Ellipsis 7 Screen Replacement: passo 12, immagine 1 di 2 Verizon Ellipsis 7 Screen Replacement: passo 12, immagine 2 di 2
    • After you remove the motherboard, remove the other two boards by unscrewing the 4 screws with a Phillips #00 screwdriver.
    • Remove the tape section of the sheet metal plate with the flat end of a spudger.
    • This might cause damage to your device. Be very careful when scrapping the plate off of the device.
  13. Verizon Ellipsis 7 Screen Replacement: passo 13, immagine 1 di 2 Verizon Ellipsis 7 Screen Replacement: passo 13, immagine 2 di 2
    • Remove the metal plate from the screen.
Conclusione
Altre 10 persone hanno completato questa guida.
Scott Mangin
Membro da: 01/24/17
609 Reputazione
2 Guide realizzate
Cal Poly, Team 13-5, Banghart Winter 2017 Membro di Cal Poly, Team 13-5, Banghart Winter 2017
CPSU-BANGHART-W17S13G5
4 Membri
4 Guide realizzate
6 Commenti
Applause for the person for uploading this repair.
Asadullah Baig - Replica
should go one step further and include digitizer replacement
Daniel Blue - Replica
ok, so to remove the screen from the frame (for digitizer replacement) i set the heat-bed of my 3d printer to 80c, placed the front bezel with screen and digitizer glass side down on the heater and let it sit for about 2 min.
at that point the perimeter glue was soft enough that i could carefully go aroung the lcd with a sharpened gift card and slowly work it away from the glass and frame.
once the lcd is out (hopefully not broken) i used the same method but with a bit more gusto in order to remove the digitizer from the plastic bezel.
revers steps for reinstall.
So if I don't have a heat bed what else would I be able to use?
Jenny Mena - Replica
Too hard i only paid 50$ for it. Oh
Larry Patterson - Replica
when I turn on arndion it just stay on battery the screen is crank how much will it cost to fix
Eric Lopez - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 19
Tutti i Tempi: 9,569
