Introduzione
This guide will show how to replace a defective power button on the Verizon Ellipsis 7.
Cosa ti serve
Power down device by holding down the power button until the screen goes black.
Remove the SIM card from the device to prevent damage.
To remove the SIM card, open the SIM card cover on the side of the device.
Push SIM card in, then remove after it pops out with an audible click.
Remove the charging (micro-USB) port by unscrewing the indicated screws using the Phillips #00 screwdriver.
Disconnect the ribbon cable connecting the charging port board to the motherboard using tweezers.
Use the tweezers to grab the sides of black, plastic connector. Do not grab from the wires or try to wedge it out from the bottom.
Be extremely careful when disconnecting the ribbon cable. It is very delicate.
Desolder the power button from the motherboard.
Learn how to solder and desolder components here!
Altre 2 persone hanno completato questa guida.
2 Commenti
I dropped mine and the button is broke. It looks like I should be able to just pop it back, but it's not reaching the button in the tablet. Do I really have to order this just for it to turn on? I mean, I use a paper clip, but I use this for Uber and it's not safe when I'm driving, lol.
I have looked everywhere for replacement buttons. Any help you can give in finding the parts is appreciated.
