Salta al contenuto principale
Venturer CR20 Power Cord Replacement
Cosa ti serve
  1. Venturer CR20 Power Cord Replacement, Front Screen: passo 1, immagine 1 di 1
    • On the bottom of the clock locate and unscrew the single 2mm Phillips screw from bottom of the clock.
  2. Venturer CR20 Power Cord Replacement: passo 2, immagine 1 di 2 Venturer CR20 Power Cord Replacement: passo 2, immagine 2 di 2
    • Using a moderate amount of force, position the screwdriver in the crack between the front screen and the main body of the clock (as shown) and push the screen away from the main body of the clock.
  3. Venturer CR20 Power Cord Replacement, Power Cord: passo 3, immagine 1 di 2 Venturer CR20 Power Cord Replacement, Power Cord: passo 3, immagine 2 di 2
    • Get a firm grip on the outside of the clock and a firm grip on the hardware on the inside of the the clock like so and pull the hardware out from the outside of the clock.
  4. Venturer CR20 Power Cord Replacement: passo 4, immagine 1 di 3 Venturer CR20 Power Cord Replacement: passo 4, immagine 2 di 3 Venturer CR20 Power Cord Replacement: passo 4, immagine 3 di 3
    • Using your fingers, pull the power cord connector, outlined in the picture with a red rectangle straight up to disconnect from the alarm clock.
Conclusione
Robert Myers
Membro da: 01/11/13
54 Reputazione
5 Guide realizzate
Cal Poly, Team 5-15, Forte Winter 2013 Membro di Cal Poly, Team 5-15, Forte Winter 2013
CPSU-FORTE-W13S5G15
5 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 14
Tutti i Tempi: 393
