Introduzione
This guide will show how to safely remove the RAM from the NoteMagix M10 A82 netbook.
Parti
Nessuna parte richiesta.
  1. Place the notebook on the table, with the battery facing away from you. Slide the switch from "lock" to "unlock" with your right hand on the right side of the computer.
    • Place the notebook on the table, with the battery facing away from you.
    • Slide the switch from "lock" to "unlock" with your right hand on the right side of the computer.
    • Maintain holding the right switch in the "unlock" position.
    • Use your left hand to slide the left switch from "lock" to "unlock".
  2. Maintain both left and right switches in the "unlock" position. Use your forefingers to push the battery out of the computer.
    • Maintain both left and right switches in the "unlock" position.
    • Use your forefingers to push the battery out of the computer.
  3. Spedizione gratuita per tutti gli ordini superiori a 100 US$ o contenenti un Kit Attrezzi Pro Tech!
    Sfoglia il Nostro Negozio
  4. Locate the DDR panel and unscrew the two 3.65mm Phillips #1 screws holding it in place. Use the spudger to lift the DDR panel off.
    • Locate the DDR panel and unscrew the two 3.65mm Phillips #1 screws holding it in place.
    • Use the spudger to lift the DDR panel off.
  5. Push in the tabs on the sides that contain the RAM. Gently raise the RAM up to a 45 degree angle and gently pull the RAM towards you. Gently raise the RAM up to a 45 degree angle and gently pull the RAM towards you.
    • Push in the tabs on the sides that contain the RAM.
    • Gently raise the RAM up to a 45 degree angle and gently pull the RAM towards you.
Conclusione
Sam Middleton
Membro da: 01/10/2013
401 Reputazione
4 Guide realizzate
Cal Poly, Team 14-9, Forte Fall 2013 Membro di Cal Poly, Team 14-9, Forte Fall 2013
CPSU-FORTE-F13S14G9
5 Membri
6 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 6
Tutti i Tempi: 226
