Introduzione
You will use your hands to remove the power source of the notebook. A very simple task to complete.
  1. Place the notebook on the table, with the battery facing away from you. Slide the switch from "lock" to "unlock" with your right hand on the right side of the computer.
    • Place the notebook on the table, with the battery facing away from you.
    • Slide the switch from "lock" to "unlock" with your right hand on the right side of the computer.
    • Maintain holding the right switch in the "unlock" position.
    • Use your left hand to slide the left switch from "lock" to "unlock".
  2. Spedizione gratuita per tutti gli ordini superiori a 100,00 US$ o contenenti un Kit Attrezzi Pro Tech!
    Sfoglia il Nostro Negozio
  3. Maintain both left and right switches in the "unlock" position. Use your forefingers to push the battery out of the computer.
    • Maintain both left and right switches in the "unlock" position.
    • Use your forefingers to push the battery out of the computer.
Conclusione
Sam Middleton
Membro da: 01/10/2013
401 Reputazione
4 Guide realizzate
Cal Poly, Team 14-9, Forte Fall 2013 Membro di Cal Poly, Team 14-9, Forte Fall 2013
CPSU-FORTE-F13S14G9
5 Membri
6 Guide realizzate
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 319
