Introduzione
VanMoof's are fantastic-looking bikes but quite heavy and I found the 3-speed gear way too over-geared for the hills here in Sydney. Converting to an 8-speed suddenly made my bike much more usable.
It's really important you get the correct hub gear (36 spoke, with coaster brake) - I brought the wrong one first so don't make my mistake! Gears last for a long time so I was happy to use a second-hand one.
Spreading the dropout to take the new gear was a concern so I had this done at a bike store and there's no evidence of damage.
Cosa ti serve
Shimano SG-C6001-8C Nexus 8. This is the one with the coaster brake.
Chain ring, gear lever, seals, and clips
Shimano Grip Shifter Nexus 8-speed Sl-C60008
Gear cable (inner and outer)
Spokes 36 * 284mm stainless steel spokes
Measure the inside diameter of your wheel
Use this calculator https://leonard.io/edd/
Add 2mm. You should get 284mm spokes
I brought silver Halo spokes from ebay. They are decent quality and have not rusted.
You need to stretch the rear frame dropouts because the 8-speed hub is wider (135mm) than the 3-speed one (110mm)
I got my local bike shop to do this because there's a risk for damaging your frame.
The cost was $150 AUD
Remove all the old spokes from your wheel
Spoke the 8 speed gear into the wheel. This is the best guide https://www.youtube.com/watch?v=mIU6mi0K...
Tighten all the spokes using a screwdriver. Use the same torque on the screwdriver and check by "plucking" the spokes so they sound the same
Turn the bike upside down, install the wheel, and true the wheel. I hold a screwdriver against the frame and slowly spin the wheel. When it moves in, I just tighten the opposite spokes
Pull the old inner cable out from the front
Push the new inner cable into the old outer cable
Pull the old outer gear cable out of the back of the bottom of the frame. LEAVE THE INNER CABLE IN so you can use it as a guide through the frame.
Push the new outer cable in from the back
Remove the handlebar grip. I pushed a spoke between the grip and the bar and rolled the spoke to loosen the grip
Install new gear change
Replace the handle bar grip. I wiped the handle bar and inside grip with alcohol.
2 Commenti
Would this be a possible solution for a bike with a broken eshifter? I have an x3 with err44 and cannot find a replacement part.
I've seen a few e-shifters for sale on facebook, and there are guides on how to fix the electronics so I'd probably go that route. The main problem I can think of with changing to the 8 speed is you'll need to deal with e-shifter wire and you'll need to route the gear change cable on frame. Good luck!
