Salta al contenuto principale
Vanmoof No 3 Replacement Mudguards
  1. Vanmoof No 3  Replacement Mudguards, Get the Mudguards: passo 1, immagine 1 di 1
    • Make sure you get 2 mudguards, one set of stays that are straight for the rear, and a second that have a bend. Also make sure you have the two rear connection pieces.
  2. Vanmoof No 3  Replacement Mudguards, The problem: passo 2, immagine 1 di 1
    • You need to cut both sides of the mudguard so it can fit between the chain stays, and drill a new hole to attach to the bottom of the frame.
  3. Vanmoof No 3  Replacement Mudguards, Cut the rear mudguard: passo 3, immagine 1 di 3 Vanmoof No 3  Replacement Mudguards, Cut the rear mudguard: passo 3, immagine 2 di 3 Vanmoof No 3  Replacement Mudguards, Cut the rear mudguard: passo 3, immagine 3 di 3
    • The rear mudguard will need to be cut at the front.
    • First cut at parallel to the bottom about 16mm long
    • Second cut is 7mm in from the rounded edge
  4. Vanmoof No 3  Replacement Mudguards, Bend over the metal to make the edge: passo 4, immagine 1 di 3 Vanmoof No 3  Replacement Mudguards, Bend over the metal to make the edge: passo 4, immagine 2 di 3 Vanmoof No 3  Replacement Mudguards, Bend over the metal to make the edge: passo 4, immagine 3 di 3
    • Bend the edges over so you make a rounded lip
  5. Vanmoof No 3  Replacement Mudguards, Drill the new hole: passo 5, immagine 1 di 1
    • Drill the frame attachment hole
    • Bolt to the frame
Conclusione
Martin Hampton
Membro da: 02/13/16
1.308 Reputazione
7 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 16
Tutti i Tempi: 987
