Salta al contenuto principale
VanMoof No 3 Light Battery Replacement
Cosa ti serve
  1. VanMoof No 3 Light Battery Replacement, Battery: passo 1, immagine 1 di 3 VanMoof No 3 Light Battery Replacement, Battery: passo 1, immagine 2 di 3 VanMoof No 3 Light Battery Replacement, Battery: passo 1, immagine 3 di 3
    • Buy two, "2/3" AAA NiCad rechargeable batteries. Better still get four so you can replace the batteries in both lights.
    • Get the batteries with solder tabs
  2. VanMoof No 3 Light Battery Replacement, Disassemble the light: passo 2, immagine 1 di 1
    • Nothing to it really - just remove the 2 cross point screws
  3. VanMoof No 3 Light Battery Replacement, Remove the battery: passo 3, immagine 1 di 2 VanMoof No 3 Light Battery Replacement, Remove the battery: passo 3, immagine 2 di 2
    • Use a flat blade screw driver to pull the battery from the adhesive tape.
    • Remove the heat shrink plastic joining the batteries
  4. VanMoof No 3 Light Battery Replacement, Unsolder the battery: passo 4, immagine 1 di 2 VanMoof No 3 Light Battery Replacement, Unsolder the battery: passo 4, immagine 2 di 2
    • Unsolder the wires
  5. VanMoof No 3 Light Battery Replacement, Solder the new battery: passo 5, immagine 1 di 3 VanMoof No 3 Light Battery Replacement, Solder the new battery: passo 5, immagine 2 di 3 VanMoof No 3 Light Battery Replacement, Solder the new battery: passo 5, immagine 3 di 3
    • Tin the battery tabs
    • Join together with tape. You'll remove this later. Both +ve ends are joined
    • The red wire goes on the end of the battery that has a ridge.
  6. VanMoof No 3 Light Battery Replacement, Join the batteries: passo 6, immagine 1 di 1
    • Remove the temporary tape
    • Fold the tabs inwards
    • Cover with 2 pieces of insulation tape. The wires will come out of the middle, between the pieces of tape
  7. VanMoof No 3 Light Battery Replacement, Reassemble: passo 7, immagine 1 di 3 VanMoof No 3 Light Battery Replacement, Reassemble: passo 7, immagine 2 di 3 VanMoof No 3 Light Battery Replacement, Reassemble: passo 7, immagine 3 di 3
    • Put the small black cup back on the switch. The dome goes outwards.
    • Put the outer switch in the lense. It goes in the smaller hole
    • The black body will be flush when it's pushed together.
  8. VanMoof No 3 Light Battery Replacement, Reassemble 2: passo 8, immagine 1 di 2 VanMoof No 3 Light Battery Replacement, Reassemble 2: passo 8, immagine 2 di 2
    • Test the light turns on
    • Screw the back plate to the lense.
Conclusione
Altre 3 persone hanno completato questa guida.
Martin Hampton
Membro da: 02/13/16
1.308 Reputazione
7 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 34
Ultimi 30 Giorni: 135
Tutti i Tempi: 7,720
