Introduzione
This is the second time one of the buttons stopped working correctly, caused by wetness.
The first time it was the boost button, following with an error 41, I took a trip to Amsterdam to get it fixed fast. They shipped my bike back a week later.
This time it hit the bell button, it got wet and stuck.
First I tried to fix it with compressed air and ethanol. It worked for a while, but then it started to double tap every time it got pushed.
So I could not unlock the bike without a phone.
This time I wanted to try to fix it myself.
I called for support, and they sent me a replacement cable, telling that it will be an easy task.
But they have not sent a manual, and I could not find any tutorials online. So I just tried it myself.
Here is the result.
I hope this helps!
Cosa ti serve
In my case the button was glued additionally. Cut around it to make it loose.
Use the 2mm hex screwdriver and remove the tiny screw on the side of the bell housing.
Use the pliers to unscrew the button. Screw to the left.
Loosen the 5mm screw located below the button.
This screw holds the break/button part on the wheel. Later, you will need to pull it off. As you can see, the cable goes through the rubber grips.
Use the wrench and the cloth to remove the handle grips. The cable goes through it - then through the handlebar.
Unscrew the handlebar with the 5mm hex wrench.
Remove the rubber cap located underside the handlebar. Remember where you put it.
In my case the bell button was the unmarked cable. Start to pull it to get the new one through. Good luck!
Attrezzo utilizzato in questo passaggio:Tweezers$4.99
If you are unlucky and loose the cable inside. Try to fix it to a wire.
You can also try to use the wire, to block the path through that hole in the wheel, and push just the cable. It should than bend and appear in the hole.
Use the hole and the tweezers to get the cable halfway through.
Connect the cables. And try the bell.
Put everything back together. Use some proper electrical tape to get the cable in place.
I removed the old glue with the tweezers and applied some fresh hot glue.
7 Commenti
https://www.ebay.de/itm/115776735689 i was sold out.
Vielen Dank für diese ausführliche Anleitung. Das hat mir wirklich sehr geholfen beim E41!
Moin hätte eine Frage welche Größe hat die Mini Schraube an der Seite vom Knopf hab sie verloren Weis jetzt nicht ob m2 oder 2.5 würde mich über eine Antwort freuen
