Introduzione
This guide contains a selection of photos and chip identification summary for the Valve Index.
Check out our Valve Index teardown for more details.
Special thanks to community member CChin for his contribution!
Panoramica Video
Chip ID, part 1:
Lattice Semiconductor iCE40HX8K-CB132 iCE40 HX FPGA
Nordic Semiconductor nRF52840 Bluetooth low energy 5.3 SoC
EtronTech eSP776U FHD multi-camera ISP bridge
Winbond W25Q32JW 4 MB serial NOR flash memory
Analogix ANX7530 SlimPort 4K UHD receiver
Cirrus Logic CS47L35 audio codec w/ DSP
Nuvoton NPCA110PA0YX audio enhancing engine and codec
Chip ID, part 2:
Microchip USB5744 4-port USB hub controller
VIA Labs VL671-Q4 USB 2.0 to USB 3.1 transaction translator
Texas Instruments LP8556SQ-E09 LED backlight driver
Texas Instruments LP5562 4-ch LED driver w/ program memory
Texas Instruments TS3A5223 2-ch. SPDT analog switch
Toll Microelectronic TMI3255T 5 A synchronous step-down converter
Texas Instruments TPS22915C 2 A load switch
Chip ID, part 3:
Texas Instruments LP5907MFX-3.3 250 mA / 3.3 V LDO regulator
Texas Instruments LP2951-50 100 mA / 5.0 V LDO regulator
Chip ID, part 1:
Microchip ATSAMG55J19B-MU 32-bit ARM Cortex-M4 microcontroller w/ flash - 32 kB
NXP Semiconductor LPC11U14 32-bit ARM Cortex-M0 microcontroller w/ flash - 32 kB
Winbond W25X10CL 1 Mb serial NOR flash memory
Macronix MX25L512E 64 KB serial NOR flash memory
Goodix TFA9892 13.2 W class-D audio amplifier
Texas Instruments TPS65132T6 dual output power supply
Chip ID, part 2:
Texas Instruments TS5USBC41x USB 2.0 dual SPDT analog switch w/ overvoltage protection
Texas Instruments TS3USB30E USB 2.0 dual-channel SPDT analog switch
Texas Instruments TPS562201 2 A synchronous step-down converter
Texas Instruments TPS563209 3 A synchronous step-down voltage regulator
Texas Instruments TPS259571 eFuse w/ overvoltage protection
Texas Instruments TPS2H000-Q1 2-ch. smart high-side power switch
Chip ID, part 3:
Texas Instruments TPS22970 4 A load switch
Texas Instruments TLV70728P 200 mA / 2.8 V LDO regulator
Nexperia 74LVC157A quad 2-input multiplexer
Texas Instruments TCA9803 2-bit level-translating bus buffer/repeater
Texas Instruments SN74AUP2G125 dual bus buffer
Texas Instruments SN74AVC4T245 4-bit dual-supply bus transceiver
Chip ID, part 1:
Fitipower Integrated Tech FP6183-12X7 300 mA / 1.2 V LDO regulator
onsemi NCP161AMX330TBG 450 mA / 3.3 V LDO regulator
Renesas load switch (likely)
Chip ID, part 1:
Lattice Semiconductor iCE40HX8K-BG121 iCE40 HX FPGA
Cirque 1CA037 touch controller
Texas Instruments BQ24297 3 A Li-Ion battery charger
Texas Instruments BQ27421-G1D battery fuel gauge
Renesas mixed signal array
Texas Instruments TPS630250 2 A buck-boost converter
onsemi NCP161AMX300TBG 450 mA / 3.0 V LDO regulator
1Commento della guida
Is this repairable like the Steam Deck? Has Valve become a repair friendly company or no?
