Introduzione
This is a guide to fix base station 2.0.
Cosa ti serve
Score the front plastic.
Use the soldering iron to cut part of it until you can open it with pliers.
Use a T8 screwdriver to remove the four screws that are marked with a blue circle.
Use needle-nose pliers to pry out the piece marked by the blue circle.
Altre 3 persone hanno completato questa guida.
8 Commenti
Can you use HLD830030N5T, 5,6mm TO18 30mW 830nm Laser diodes as replacement or is the wattage different?
Thank you for the Info that the 1.0 Laser works in the 2.0 Variant!
TLDR, no you need 200mw to replace it.
The wattage for a base station laser is 200mW 830nm. With a 30mW I would expect the laser to immediately burn out because of constant current output.
Thank you very much!
for instance would this work?
