Salta al contenuto principale
VTechCS6719-16 Screen Replacement
Cosa ti serve
  1. VTechCS6719-16 Screen Replacement, Screen: passo 1, immagine 1 di 1
    • Slide the back cover off the cause.
  2. VTechCS6719-16 Screen Replacement: passo 2, immagine 1 di 1
    • Lift the battery.
    • Unplug the two pin cable from the connector.
  3. VTechCS6719-16 Screen Replacement: passo 3, immagine 1 di 1
    • Unscrew the two 10mm screws in phone base.
  4. VTechCS6719-16 Screen Replacement: passo 4, immagine 1 di 1
    • Using the metal spudger gently, but firmly edge along the device .
    • When you feel a hook or latch use a firm but gentle lifting motion upward to unlatch the front and back case.
  5. VTechCS6719-16 Screen Replacement: passo 5, immagine 1 di 1
    • Unscrew a second set of 10mm screws to access to the other side.
  6. VTechCS6719-16 Screen Replacement: passo 6, immagine 1 di 1
    • The front case is now free and able to be manipulated.
    • Set aside the circuit board and back case as they will get in the way.
  7. VTechCS6719-16 Screen Replacement: passo 7, immagine 1 di 1
    • Using a single finger apply a light force on the screen cover to release from the case.
    • Now the old screen can be replaced with a new desired one, simply properly align and it will clip into place.
Conclusione
UMass Dartmouth, Team 5-5, Martin Fall 2016 Membro di UMass Dartmouth, Team 5-5, Martin Fall 2016
UMASSD-MARTIN-F16S5G5
3 Membri
10 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 54
Tutti i Tempi: 374
