Salta al contenuto principale
VTech Write and Learn Creative Center Magnetic Screen Replacement
Cosa ti serve
  1. VTech Write and Learn Creative Center Magnetic Screen Replacement, Back Panel: passo 1, immagine 1 di 3 VTech Write and Learn Creative Center Magnetic Screen Replacement, Back Panel: passo 1, immagine 2 di 3 VTech Write and Learn Creative Center Magnetic Screen Replacement, Back Panel: passo 1, immagine 3 di 3
    • Remove all eleven 9mm PH 2 Phillips screws securing the back of the case.
  2. VTech Write and Learn Creative Center Magnetic Screen Replacement, Slider: passo 2, immagine 1 di 1
    • Remove the two 7mm PH 0 Phillips screws holding the slider to the slider handle.
    • The back of the slider will likely be coated in lubricant. Be careful not to make a mess.
  3. VTech Write and Learn Creative Center Magnetic Screen Replacement, Magnetic Screen: passo 3, immagine 1 di 2 VTech Write and Learn Creative Center Magnetic Screen Replacement, Magnetic Screen: passo 3, immagine 2 di 2
    • Remove the four 5mm PH 0 Phillips screws with 7mm heads holding the screen to the front of the case.
  4. VTech Write and Learn Creative Center Magnetic Screen Replacement: passo 4, immagine 1 di 1
    • Gently push the edges of the screen to remove it from the front case.
Conclusione
2Commenti sulla guida
Thank you for this! Do you have suggestions on how to fix the magnetic screen or get a replacement? I emailed the manufacturer (B. Toys for mine) and unfortunately they replied, “​We replace the full toy only, and do not offer the internal parts as replacements.“ But I don’t want all the rest of the plastic - I just want the magnets on the screen to properly appear and disappear. Instead, its like the magnetic powder floats so it’s constantly grey rather than clear or magnetized.
Katie - Replica
Hello I got the same issue i dont know how to fix ot of you mine is not even an year old but still get that grey screen plz help n let me know how to get rid of it Thankyou
wings_latif -
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 15
Tutti i Tempi: 1,613
