Salta al contenuto principale
VTech VM3254 Camera Speaker Replacement
Cosa ti serve
  1. VTech VM3254 Camera Speaker Replacement, Camera Circuit Board: passo 1, immagine 1 di 3 VTech VM3254 Camera Speaker Replacement, Camera Circuit Board: passo 1, immagine 2 di 3 VTech VM3254 Camera Speaker Replacement, Camera Circuit Board: passo 1, immagine 3 di 3
    • Remove the two 8 mm Phillips #00 screws from the back of the device.
    • Use the Jimmy tool to open the case.
    • You may need to use an opening pick to hold it open.
    • Remove the face from the case.
  2. VTech VM3254 Camera Speaker Replacement: passo 2, immagine 1 di 2 VTech VM3254 Camera Speaker Replacement: passo 2, immagine 2 di 2
    • Remove the three 8 mm Phillips #00 screws from the board.
    • Gently remove the board from the case.
    • Be careful, there are wires connecting the board to the case that could be damaged.
  3. VTech VM3254 Camera Speaker Replacement, Camera Speaker: passo 3, immagine 1 di 3 VTech VM3254 Camera Speaker Replacement, Camera Speaker: passo 3, immagine 2 di 3 VTech VM3254 Camera Speaker Replacement, Camera Speaker: passo 3, immagine 3 di 3
    • Unscrew and remove the two 7 mm Phillips #0 screws that secure the speaker.
    • Remove the speaker.
    • Desolder the speakers cords from the motherboard.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 24
Tutti i Tempi: 187
