Salta al contenuto principale
VTech VM3254 Battery Replacement
Cosa ti serve
  1. VTech VM3254 Battery Replacement, Battery: passo 1, immagine 1 di 2 VTech VM3254 Battery Replacement, Battery: passo 1, immagine 2 di 2
    • Turn the monitor on its back, and remove the two 8 mm Phillips #0 case screws.
  2. VTech VM3254 Battery Replacement: passo 2, immagine 1 di 3 VTech VM3254 Battery Replacement: passo 2, immagine 2 di 3 VTech VM3254 Battery Replacement: passo 2, immagine 3 di 3
    • Use the iFixit Jimmy tool to begin removing the face of the monitor.
    • You may need to use an opening pick to hold the screen open as you move the Jimmy tool around all the edges of the device.
    • Once the screen has been separated, lift it from the case.
    • Be gentle while removing the screen. There are wires connected to the two pieces that may be damaged.
  3. VTech VM3254 Battery Replacement: passo 3, immagine 1 di 2 VTech VM3254 Battery Replacement: passo 3, immagine 2 di 2
    • Remove the four 8 mm Phillips #00 screws from the bracket that secures the battery.
    • Remove the bracket.
  4. VTech VM3254 Battery Replacement: passo 4, immagine 1 di 3 VTech VM3254 Battery Replacement: passo 4, immagine 2 di 3 VTech VM3254 Battery Replacement: passo 4, immagine 3 di 3
    • Gently remove the battery from its location.
    • Carefully disconnect the bundled cable connector from the circuit board.
Conclusione
Jackson Meacham
Membro da: 02/14/23
109 Reputazione
1 Guida realizzata
1Commento della guida
What is the battery that needs to be replaced called?
Aden Brooks - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 16
Ultimi 30 Giorni: 74
Tutti i Tempi: 2,006
