Salta al contenuto principale
VTech Safe And Sound DM221 Speaker Replacement
Cosa ti serve
  1. VTech Safe And Sound DM221 Speaker Replacement, Speaker: passo 1, immagine 1 di 1
    • Remove the battery cover.
  2. VTech Safe And Sound DM221 Speaker Replacement: passo 2, immagine 1 di 1
    • Unplug the battery from its connector and remove.
  3. VTech Safe And Sound DM221 Speaker Replacement: passo 3, immagine 1 di 1
    • Using the Phillips #00 screwdriver, unscrew the two 5.0 mm Phillips #00 screws at the bottom of the monitor.
  4. VTech Safe And Sound DM221 Speaker Replacement: passo 4, immagine 1 di 1
    • Separate the back half of the device from the front using the metal spudger.
  5. VTech Safe And Sound DM221 Speaker Replacement: passo 5, immagine 1 di 1
    • Remove the two 5.0 mm Phillips #00 screws at the top of the device which holds the antenna at the top of the motherboard.
    • This will allow the removal of the silver handle.
  6. VTech Safe And Sound DM221 Speaker Replacement: passo 6, immagine 1 di 1
    • Remove the “TALK” button to get access to remove the motherboard.
  7. VTech Safe And Sound DM221 Speaker Replacement: passo 7, immagine 1 di 1
    • Push down on the antenna, located on the top of the motherboard.
  8. VTech Safe And Sound DM221 Speaker Replacement: passo 8, immagine 1 di 1
    • Gently remove the motherboard away from the monitor.
    • Be careful not to disconnect the red wire.
  9. VTech Safe And Sound DM221 Speaker Replacement: passo 9, immagine 1 di 1
    • Use the plastic spudger to push the two white plastic tabs, at the bottom of the device, up to release the metal retaining clip.
Conclusione
Krystal
Membro da: 10/01/15
600 Reputazione
5 Guide realizzate
USF Tampa, Team 1-5, Leahy Fall 2015 Membro di USF Tampa, Team 1-5, Leahy Fall 2015
USFT-LEAHY-F15S1G5
4 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 5
Tutti i Tempi: 334
