Salta al contenuto principale
VTech Record and Learn KidiStudio Whammy Bar Replacement
Cosa ti serve
  1. VTech Record and Learn KidiStudio Whammy Bar Replacement, Whammy Bar: passo 1, immagine 1 di 2 VTech Record and Learn KidiStudio Whammy Bar Replacement, Whammy Bar: passo 1, immagine 2 di 2
    • Unscrew 11 PH2 screws (7 mm).
    • Remove black plastic backing.
    • Remove the batteries from the toy before beginning replacement of the whammy bar.
  2. VTech Record and Learn KidiStudio Whammy Bar Replacement: passo 2, immagine 1 di 2 VTech Record and Learn KidiStudio Whammy Bar Replacement: passo 2, immagine 2 di 2
    • Remove PH2 screw (5 mm) from yellow/gold colored circuit board and pull back to access the whammy component.
  3. VTech Record and Learn KidiStudio Whammy Bar Replacement: passo 3, immagine 1 di 2 VTech Record and Learn KidiStudio Whammy Bar Replacement: passo 3, immagine 2 di 2
    • Remove 3 PH2 (5 mm) screws connected to the whammy bar component.
    • Remove blue piece from back of the device. This will free the whammy bar. Replace the whammy bar with new part.
Conclusione
UW Tacoma, Team 1-1, Rose Winter 2016 Membro di UW Tacoma, Team 1-1, Rose Winter 2016
UWT-ROSE-W16S1G1
5 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 4
Tutti i Tempi: 206
