Salta al contenuto principale
VTech MobiGo Touch Learning System Screen Replacement
Cosa ti serve
  1. VTech MobiGo Touch Learning System Screen Replacement, Case: passo 1, immagine 1 di 1
    • Remove the battery covers and the four batteries.
  2. VTech MobiGo Touch Learning System Screen Replacement: passo 2, immagine 1 di 2 VTech MobiGo Touch Learning System Screen Replacement: passo 2, immagine 2 di 2
    • Remove the four plastic caps with a metal spudger to expose the 6.0 mm Philips JIS #0 case screws.
    • Remove the eight 6.0 mm JIS #0 case screws.
  3. VTech MobiGo Touch Learning System Screen Replacement: passo 3, immagine 1 di 2 VTech MobiGo Touch Learning System Screen Replacement: passo 3, immagine 2 di 2
    • Using a plastic opening tool, separate the two pieces of the case carefully.
  4. VTech MobiGo Touch Learning System Screen Replacement, Disassembling VTech MobiGo Touch Learning System Screen Enclosure: passo 4, immagine 1 di 1
    • Remove the three 4.0 mm Philips J0 screws holding the "L" shaped brackets in place.
  5. VTech MobiGo Touch Learning System Screen Replacement: passo 5, immagine 1 di 1
    • Remove the three "L" shaped brackets and the spring.
  6. VTech MobiGo Touch Learning System Screen Replacement: passo 6, immagine 1 di 1
    • Flip the device over and remove the three 4.0 mm Philips J0 case screws.
  7. VTech MobiGo Touch Learning System Screen Replacement: passo 7, immagine 1 di 1
    • Separate the front and back of the case.
    • Use a plastic opening tool if necessary.
  8. VTech MobiGo Touch Learning System Screen Replacement, Screen: passo 8, immagine 1 di 1
    • Remove the 4 (3.4 mm Philips J0) screws holding the screen in
  9. VTech MobiGo Touch Learning System Screen Replacement: passo 9, immagine 1 di 1
    • Remove the black tape
  10. VTech MobiGo Touch Learning System Screen Replacement: passo 10, immagine 1 di 1
    • Remove the circuit board from the back of the screen.
    • The circuit board has double sided tape on the back side holding it to the screen.
  11. VTech MobiGo Touch Learning System Screen Replacement: passo 11, immagine 1 di 1
    • Peel the ribbon wire off of the circuit board. Now the screen should be free to remove.
  12. VTech MobiGo Touch Learning System Screen Replacement: passo 12, immagine 1 di 1
    • Resolder the new screens ribbon cable on the the circuit board.
    • Always be careful when soldering.
Conclusione
USF Tampa, Team 8-3, Eyestone Fall 2015 Membro di USF Tampa, Team 8-3, Eyestone Fall 2015
USFT-EYESTONE-F15S8G3
3 Membri
17 Guide realizzate
1Commento della guida
mine i droped a rock on so i don’t get it
Jesse Eagan - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 27
Tutti i Tempi: 954
