Salta al contenuto principale
VTech MobiGo Touch Learning System Buttons Replacement
Cosa ti serve
    1. VTech MobiGo Touch Learning System Buttons Replacement, Case: passo 1, immagine 1 di 1
      • Remove the battery covers and the four batteries.
      Chiedi a FixBot
      Aggiungi Commento
    2. VTech MobiGo Touch Learning System Buttons Replacement: passo 2, immagine 1 di 2 VTech MobiGo Touch Learning System Buttons Replacement: passo 2, immagine 2 di 2
      • Remove the four plastic caps with a metal spudger to expose the 6.0 mm Philips JIS #0 case screws.
      • Remove the eight 6.0 mm JIS #0 case screws.
      Chiedi a FixBot
      Aggiungi Commento
    3. VTech MobiGo Touch Learning System Buttons Replacement: passo 3, immagine 1 di 2 VTech MobiGo Touch Learning System Buttons Replacement: passo 3, immagine 2 di 2
      • Using a plastic opening tool, separate the two pieces of the case carefully.
      Chiedi a FixBot
      Aggiungi Commento
    1. VTech MobiGo Touch Learning System Buttons Replacement, Disassembling VTech MobiGo Touch Learning System Screen Enclosure: passo 4, immagine 1 di 1
      • Remove the three 4.0 mm Philips J0 screws holding the "L" shaped brackets in place.
      Chiedi a FixBot
      Aggiungi Commento
    2. VTech MobiGo Touch Learning System Buttons Replacement: passo 5, immagine 1 di 1
      • Remove the three "L" shaped brackets and the spring.
      Chiedi a FixBot
      Aggiungi Commento
    3. VTech MobiGo Touch Learning System Buttons Replacement: passo 6, immagine 1 di 1
      • Flip the device over and remove the three 4.0 mm Philips J0 case screws.
      Chiedi a FixBot
      Aggiungi Commento
    4. VTech MobiGo Touch Learning System Buttons Replacement: passo 7, immagine 1 di 1
      • Separate the front and back of the case.
      • Use a plastic opening tool if necessary.
      Chiedi a FixBot
      Aggiungi Commento
    1. VTech MobiGo Touch Learning System Buttons Replacement, Buttons: passo 8, immagine 1 di 1
      • Remove 6 (3.8 mm Philips J0) screws holding the buttons in.
      Chiedi a FixBot
      Aggiungi Commento
    2. VTech MobiGo Touch Learning System Buttons Replacement: passo 9, immagine 1 di 2 VTech MobiGo Touch Learning System Buttons Replacement: passo 9, immagine 2 di 2
      • From here you can remove and replace the buttons.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
USF Tampa, Team 8-3, Eyestone Fall 2015 Membro di USF Tampa, Team 8-3, Eyestone Fall 2015
USFT-EYESTONE-F15S8G3
3 Membri
17 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 1
Ultimi 30 giorni: 19
Tutti i Tempi: 1,582
