Salta al contenuto principale
VTech Learning Tunes Karaoke Power Button Replacement
Cosa ti serve
  1. VTech Learning Tunes Karaoke Power Button Replacement, Power Button: passo 1, immagine 1 di 1
    • To remove the battery door, loosen the 4mm screw using a Flathead screwdriver.
    • A coin can also be used to loosen the screw
  2. VTech Learning Tunes Karaoke Power Button Replacement: passo 2, immagine 1 di 2 VTech Learning Tunes Karaoke Power Button Replacement: passo 2, immagine 2 di 2
    • Remove the battery door and take out the batteries.
  3. VTech Learning Tunes Karaoke Power Button Replacement: passo 3, immagine 1 di 1
    • Remove the six 9.5 mm Phillips #2 screws.
    • Remove the six 6.0 mm Phillips #2 screws.
  4. VTech Learning Tunes Karaoke Power Button Replacement: passo 4, immagine 1 di 2 VTech Learning Tunes Karaoke Power Button Replacement: passo 4, immagine 2 di 2
    • Gently pull up on the rear panel.
    • Be careful to not pull on the wire connections.
    • Gently place the back panel underneath the top panel with the tops facing each other, as shown in the picture.
  5. VTech Learning Tunes Karaoke Power Button Replacement: passo 5, immagine 1 di 1
    • Remove four 7.9 mm screws from the mode selector and voice selector trays.
  6. VTech Learning Tunes Karaoke Power Button Replacement: passo 6, immagine 1 di 1
    • Remove the two 5.6 mm screws from the power button board.
  7. VTech Learning Tunes Karaoke Power Button Replacement: passo 7, immagine 1 di 1
    • Carefully move the power button board out of the way.
    • From here you can replace the button.
Conclusione
USF Tampa, Team 7-2, Cheng Spring 2016 Membro di USF Tampa, Team 7-2, Cheng Spring 2016
USFT-CHENG-S16S7G2
4 Membri
10 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 10
Tutti i Tempi: 524
