Salta al contenuto principale
VTech Learning Tunes Karaoke Mode Selector Replacement
Cosa ti serve
  1. VTech Learning Tunes Karaoke Mode Selector Replacement, Mode Selector: passo 1, immagine 1 di 1
    • To remove the battery door, loosen the 4mm Flathead screw.
    • A coin can also be used to loosen the screw.
  2. VTech Learning Tunes Karaoke Mode Selector Replacement: passo 2, immagine 1 di 2 VTech Learning Tunes Karaoke Mode Selector Replacement: passo 2, immagine 2 di 2
    • Remove the battery door and take out the batteries.
  3. VTech Learning Tunes Karaoke Mode Selector Replacement: passo 3, immagine 1 di 1
    • Remove the six 9.5 mm Phillips #2 screws.
    • Remove the six 6.0 mm Phillips #2 screws.
  4. VTech Learning Tunes Karaoke Mode Selector Replacement: passo 4, immagine 1 di 2 VTech Learning Tunes Karaoke Mode Selector Replacement: passo 4, immagine 2 di 2
    • Gently pull up on the rear panel.
    • Be careful to not pull on the wire connections.
    • Gently place the back panel underneath the top panel with the tops facing each other, as shown in the picture.
  5. VTech Learning Tunes Karaoke Mode Selector Replacement: passo 5, immagine 1 di 1
    • Remove the two 7.9 mm Phillips #1 mode switch board screws.
  6. VTech Learning Tunes Karaoke Mode Selector Replacement: passo 6, immagine 1 di 2 VTech Learning Tunes Karaoke Mode Selector Replacement: passo 6, immagine 2 di 2
    • Once the screws have been removed, carefully move the mode switch board to expose the mode switch assembly underneath.
  7. VTech Learning Tunes Karaoke Mode Selector Replacement: passo 7, immagine 1 di 2 VTech Learning Tunes Karaoke Mode Selector Replacement: passo 7, immagine 2 di 2
    • Using a Philips #1 screwdriver, remove the two 5.6 mm screws on the switch.
    • Once the screws have been removed, you can easily remove the mode switch.
Conclusione
Adam Chaberek
Membro da: 02/09/16
137 Reputazione
1 Guida realizzata
USF Tampa, Team 7-2, Cheng Spring 2016 Membro di USF Tampa, Team 7-2, Cheng Spring 2016
USFT-CHENG-S16S7G2
4 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 7
Tutti i Tempi: 294
