Salta al contenuto principale
VTech Kidizoom Camera Connect Shutter Button Replacement
Cosa ti serve
  1. VTech Kidizoom Camera Connect Shutter Button Replacement, Front Case: passo 1, immagine 1 di 2 VTech Kidizoom Camera Connect Shutter Button Replacement, Front Case: passo 1, immagine 2 di 2
    • Remove batteries and SD card before beginning disassembly!
    • Locate the four plastic screw covers denoted by the markers and gently pry them up with the metal spudger.
  2. VTech Kidizoom Camera Connect Shutter Button Replacement: passo 2, immagine 1 di 2 VTech Kidizoom Camera Connect Shutter Button Replacement: passo 2, immagine 2 di 2
    • Remove all four (11mm) screws with the Philips #0 screwdriver.
  3. VTech Kidizoom Camera Connect Shutter Button Replacement: passo 3, immagine 1 di 3 VTech Kidizoom Camera Connect Shutter Button Replacement: passo 3, immagine 2 di 3 VTech Kidizoom Camera Connect Shutter Button Replacement: passo 3, immagine 3 di 3
    • Remove the two battery cartridges located on the underside of the camera.
    • Once cartridges are removed, use the metal spudger to pry open the top, bottom, and both sides of the camera.
  4. VTech Kidizoom Camera Connect Shutter Button Replacement: passo 4, immagine 1 di 1
    • Beware of the two black viewfinder lens falling out as you pry open the device!
    • The device should now be open and ready for further repair and/or replacement parts.
  5. VTech Kidizoom Camera Connect Shutter Button Replacement, Shutter Button: passo 5, immagine 1 di 1
    • Remove the purple plastic that covers the button and circuit board. It should slide right out from the slot it sits in.
  6. VTech Kidizoom Camera Connect Shutter Button Replacement: passo 6, immagine 1 di 1
    • Unsolder wires connected to the right side of the circuit board. Pull the wires to the side.
  7. VTech Kidizoom Camera Connect Shutter Button Replacement: passo 7, immagine 1 di 2 VTech Kidizoom Camera Connect Shutter Button Replacement: passo 7, immagine 2 di 2
    • The button/circuit board should be loose now. Gently pull out the button/circuit board to remove it from the device.
Conclusione
USF Tampa, Team 6-4, Eyestone Spring 2016 Membro di USF Tampa, Team 6-4, Eyestone Spring 2016
USFT-EYESTONE-S16S6G4
4 Membri
5 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 19
Tutti i Tempi: 1,272
